Question about Ricoh Aficio 2022 All-In-One Laser Printer
Add Toner Hello, My Ricoh 2022 is asking me to replace the toner and does not pring anymore. The problem is that The botle is still fairly full. I took it out a few times and shook the bottle. It did work "once" saying toner is low. After about 60 copies it stopped printing again. I replaced the bottle with a brand new one, but still no luck...... I get the same message to replace the Toner. Everytime I open the toner and close it up, It goes thru the motions saying that it is adding toner, but then says replace tone afterwards. Help!!!!!! David Newman 813-391-9941
  • DaveNewman Feb 23, 2008
    Thaks for the anser.
    Question,
    Other than the Hopper, Whats Bung and what old tube?
    If you mean the tube of toner, That is new,
    Thanks
Pull out hopper and remove bung of old tube from inside!.
Posted on Feb 23, 2008
Add black toner but still empty
Is it a genuine Ricoh Toner or a equivalent refill, if it is the latter then my machine would say empty when actually full. Just keep on using the machine, and have another toner on stand by.
If its a genuine Ricoh toner suggest the machine needs a clean around where the built in (toner) chip is located.
Jun 03, 2014 | Ricoh Aficio SP C820DN Laser Printer
RICOH AFICIO 2022 I got an error with the cartridge. machine says that there is no toner, put PCU
If it says there is no toner but you have toner in there, pull out the toner bottle and feel in the hopper (where the toner bottle sits) -- sometimes the gray cap from the old toner bottle gets left behind, and that will block the machine from pulling toner from the new bottle. Remove the cap and your copier should be fine.
If that doesn't fix it, you might need a new PCU. Once they start to get old, the developer gets bad and they don't have the right mix of toner and developer.
May 26, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
My gestetner 2712 has ran out of toner. i have replaced the toner, the machine takes a while to load and then comes back with load toner again. Why would it not be registering a full toner bottle?
GESTETNER 2712 PROBLEM USUSALLY SIMILAR TO RICOH 2022/1022/27 PROBLEM IN WHICH INLET IN PCU AT LOAD TONER OUPUT. wHAT YOU CAN DO ,TEK OUT THE PCU IN CHECK IF THE PCU TONER INLET IS BLOCK EITHER BY SEAL OR DUE TO INLET CLOSER MALFUNCTION CAN BE REPAIRED IF YOU HAS EXPERIENCE OPENIG UP THE PCU
Apr 06, 2010 | Gestetner 2712 Digital Imaging System...
Add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Mar 05, 2010 | Ricoh Aficio 2035 Copier
Ricoh copier imagio error used toner bottle is full
Change the used toner botle,desasembly the LCT tray,open the front cover and change the waste toner bottle.
Feb 09, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio 1022 Toner Bleeds
I ended up taking out the toner bottle completely and just running copies (with no toner in place) until they came out crisp. This used up the toner that was floating around. I was able to make about 700 copies before I needed to put the toner back in. But a **** of paper is still much cheaper than getting a service tech.
Apr 08, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Toner can be wiped off after copying - smudges
Hello sir; This problem caused by fuser roller and presure roller in heating unit, you have to take apart check it out, may be bushing broken.
Feb 18, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio 2022 All-In-One Laser Printer Logo
220 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
