Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Lost settings the #5 admin option has disapeared. this has to do with network. how do I get it back?
If the IP option was set to DHCP before it was turn off, wait at least 5 min for the network settings to show up.
Posted on Mar 09, 2008
NETWORK SETTINGS
In ADMINISTRATOR MODE ,if Network settings are not showing then wait there for few seconds it will appear.Some times It take few seconds to load.If the problem is still there then disconnect the machine from the network.Remove the network cable from the machine and again check for the network settings.They will show up now.
Mar 22, 2014 | Konica Minolta bizhub C250 All-In-One...
NETWORK SWETTINGS
If Matt9711's solution does not work you will need to go in admin mode and turn off the network then go in service mode and reinitialize the network card then power off then on and then back in to admin and turn the network back on.
Set dhcp on bizhib 250
1-Press "Utility/Counter" button from the control panel.
2-Press "Administrator settings"
3-Enter "Admin Password"=12345678
4-Press "END" button on top right corner of the screen.
5-There are two settings now, Admin1 and Admin 2.
6-Press Admin 2. the network settings
7-Now press "IP settings" in this option there will be two settings one is obtain IP auto and other is put IP manual.
in network settings you will see all the other options such as ping confirmation, DNS HOST, DNS SERVER ADDRESS, DHCP ON/OFF, SMTP etc.
Jan 29, 2013 | Konica Minolta bizhub Office Equipment &...
I lost the network settings option...how do I get is back? Would a factory reset bring it back?
it may.... what have you tried?? you need to get into admin mode then set ip there....
Aug 10, 2011 | Konica Minolta bizhub C351 All-In-One...
Need to unlock to use different network
If you're referring to "resetting" your wireless router, you only need to press a hidden button at the back of the router. Find a small hole at the back and press it using a thin object like toothpick or a wire. Press it for at least 15 seconds. After doing that, connect one PC to the router using LAN wire and log-in to the router's default address. Since you did not mention what modem you have, here are the options;
192.168.0.1 192.168.1.1 Use default Username and Passwords to set up new Wireless Protocol. Here are possible options;
UN: admin PW: admin
UN: admin PW:
UN: admin PW: password
UN: admin PW: 1234
From here, if you can log-in to Router's IP, look for the Wireless configuration options. It will allow you to set Network Keys and other security options.
Jun 04, 2011 | Computers & Internet
How can i changed the password of my router?
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings. From the center screen, select your encryption type from under the Security Options heading If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don
Feb 18, 2011 | NetGear WGR614 Router
Our Biz hub C 250 has lost the number 5 network setting option button when in admin panel settings. All other functions seem normal. This issue prevents setting or discovering the machine networking...
It hasn't lost the button but it does not appear during warm up and for several minutes afterwards, let it warm up and give it five minutes and then try admin mode it should be there then.
Feb 19, 2009 | Konica Minolta bizhub C250 All-In-One...
Lost password for wireless connection
Reset your router using the reset button. That will put everything back to factory settings.
Dec 25, 2007 | Broadcom BCM5705 Network Adapter
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
219 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
