Question about Nikon D50 Digital Camera
FLASH UNIT WON'T FIRE
Hi
I have a Nikon D50 (just out of warranty) The flash unit pops up when needed showing fully charged but won't fire. Tried all the settinings to no avail. Anybody have any ideas, maybe bulb has gone?
Ken
  • 6 more comments
  • dpierson Mar 21, 2008
    I have the same issue. My D50 will fire and external SB800 flash; however, the internal flash will not fire.
  • zephyrrc Apr 12, 2008
    Same problem : flash seems to be ready but does not fire...
    Seems to be a design issue with D50
  • Anu3 May 23, 2008
    I have the same problem with my Nikon D 50 Camera. Flash unit pops out but does not fire. Not a problem with the bulb though, one technician told must be a PROB WITH THE CIRCUIT BOARD. how can i get it fixed?
  • babyshoes Jul 06, 2008
    I have the same problem...has anyone sent it back to Nikon? how much does it cost to fix it? thanks!
  • YF88 Jul 08, 2008
    D50 Flash unit pops up but does not flash. I am currently in communications with Nikon to find problem. Have reset camera to defaults, but still no flash.
  • Anonymous Oct 20, 2008
    I have the same problem with a D50- flash unit pops up but doesn't fire. Any estimate on how much a replacement board will cost?
  • cgrey555 Oct 30, 2008
    I have same problem that occurred less than a year after I bought it. The flash just stopped firing after about 1,000 flashes. I sent mine back to Nikon, and they want to charge me $155 to fix...what a rip off. In order for to get warranty, you must sent it back before the 1 yr. warranty period expires. They won't tell me exactly what failed, and only guarantee it will continue to work for 90 days...that's generous -- that is what every consumer wants....a $600 camera that works for 90 days. Its a design flaw, hundreds of owners have reported this same problem, and Nikon takes no responsibility. I think the problem may be widespread enough to warrant a class action lawsuit. In the meantime, I'm scrapping it and moving on to Sony.
  • jmarcasa Nov 01, 2008
    mine too pops up no flash. just started. Camera is usually used with a ring flash but as of last month the pop up worked.Unit is two years old and am guessing not more than 100 flashes with the pop up .
  • 3 Answers
I had the same issue. The flash is set to go off, the camera assumes it went off, (as the record metadata shows) but it doen't go off at all, and the piture is underexposed.
I bought the 100 page repair manual, which is ONLY a dissassemble/reassemble manual with NO diagnostics. (Got it on ebay) So I was atleast able to get to the capacitor and flash bulb. I saw 300V across the capacitor leads, and the same 300Volts across the flash bulb leads. SO I am assuming that there is a transistor or relay that drops to ground to fire the flash that isn't working, or the electronic signal to drive that isn't working.
It seems most people replace the entire flash circuit board(which is near the capacitor under the left hand side). But it seems Nikon only sells parts to it certified repair facilities.
Ugh.... Looks like I'm buying a SB-600, as this is the cheepest solution. Too bad, because the on-board flash is more than decent. I hope the SB-600 thrills me enough to change my mood. :)
Posted on Oct 07, 2008
  • 667 Answers
Those Xenon flash tubes last for a long time. You likely need a new flash PCB (printed circuit board). Typically, the trigger coil is at fault when you get the ready light but no flash
Posted on Feb 08, 2008
D90 Built-in flash won't fire
Go in menu go to bracketing /flash then set for TTL
you should work to test leave lens cap on push button on left side with lightning bolt on it.
Oct 18, 2012 | Nikon DSLR D90 Digital Camera
Nikon SB600 flash won't fire
There may be a short, or it is arcing over,
Test fire it in the dark to see if you can locate the arc. If no arc, it is likely arcing in the charge capacitor or what might be left of the thyristor.. Which could mean a broken contact, solder connection or wire..
Feb 18, 2012 | Cameras
All of a sudden my sb-400 won't fire. i have changed the batteries numerous times and the red ready light is on but when i take a pic the auto flash pops up and the speedlight won't fire.
HI, I have a SB-400 with cracked housing, and hope to find a broken one to replace my part. Any offer is very much appreciated if you are interested of selling yours! Sincerely, Samantha (utwicky at gmail dot com)
May 14, 2011 | Nikon SB-400 Flash
Flash fires irregularly... good exposures, then suddenly 3 way under exposed/black then a good exposure, the a completely burnt out over-exposed shot! Completely irregular.
If you are referring to the internal flash I would say you are firing the camera faster then the flash can cycle. There is a green lightning bolt that will come on in the viewfinder when the flash has charged. If you fire the first one it may be a charged flash then again you may have popped the flash composed and tripped the shutter before the flash has had a chance to fully charge. You fire again depleting the charge some more and before it has a chance to recover you fire it again so the flash never has a chance to fully charge. You need to wait till the flash ready light come on in the viewfinder.
Dec 18, 2010 | Nikon D70s Digital Camera
Nikon D50 -flash won't fire
Try pushing the flash forward just a tiny bit. this model of Nikon has a built in problem with the flash popping up too hard. You can also try to "soften" the pop-up action with your finger instead of just letting it snap up into position.
Sep 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
The flash on my d40x will no longer fire. the flash pops but nothing else happens! i have tried resetting but to no avail. i first noticed the problem while i was travelling so i couldn't send it off to be...
I do not want to speak down to you. If you pop up the flash and it does not fire it may be the mode. If the camera is in an auto mode and it feels there is NOT enough light to take the photo it will automatically pop up the flash and take the photo using flash. If it is in auto and it pops up the flash and it does not use it you may have a problem.
In most cases the best mode to use is P. In P mode (Programmed Auto) the flash NEVER automatically pops up (I find that very annoying). It will ONLY fire after you pop it up and take a photo. So with the camera in P. Take some photos with the flash down. Then try to take some photos with the flash up. It may also help to have fully charged batteries. Flash circuit uses lots of power for a short time to charge a capacitor. If the battery is too weak to charge the capacitor it will NOT fire the flash. It may have a RED LED or an INDICATOR in the View Finder that tells you the FLASH is READY.
Dec 01, 2017 | Nikon Cameras
Nikon D80 using Bower AF 724AFN
I also purchased a Bower 724AFN to use with my D80, and experience the same problems. Received confirmation from Nikon that this flash unit is not compatible with the camera. I then purchased an SB-600 flash, and haven't looked back. It's worth the extra money for this high quality unit; fully compatible, and compliments the TTL features of the D80. I'll never deviate from original Nikon accessories again.
May 22, 2008 | Bower (724AFN) for Nikon Flash
Flash: PCB Replacement v. New Bulb!?
Oct 07, 2007 | Nikon D50 Digital Camera
Flash out of sync
I just had mine fixed by nikon and it seems as though the problem would come back every now and then. my current solution is to switch over to Manual mode and turn AF assist, AF illumination, and ISO control to "ON" and then then shoot a few shots. Then switch metering to centerweight. take a few shots, it should work correctly, then switch back to AUTO. after that, the flash should fire as normal. I just received my body back about 2 weeks ago, so i hope my "bad batch" flash unit was replaced with a known good one. if not, i don't know what to do.
Sep 18, 2006 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
435 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
