Accurian dvd player ADP3298
Accurian dvd player 3298 hookup with RCA TV F19421 through Motorola cable box
  • Anonymous Apr 29, 2008
    centrios EDW8020 Will not let me get to disc utilities;therefore I cannot
    finalize any disc.
    Dan
  • 979 Answers
And what you like to have fixed?...accordianman
Posted on Feb 08, 2008
RCA F19421 Stuck on video since switched from dishnetwork to cable
Some RCA TV's have a "video" option that requires you to use the original remote control to cycle up or down the channels.
Also, try unplugging the TV's from the power receptacle for 30 minutes....some times, that will cause the TV to reset.
With the power cord unplugged, manually push the power button on the front of the TV to discharge all capacitors.
Ensure the 30 minute is complete before plugging it back in.
Let me know if this works.
Thank you!
Jan 02, 2014 | RCA F19421 19" TV
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Rca atsc converter box remote program codes
093,085,083,091 are the codes to check. If you wish to get more, check the sites linked here.http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Pull up previous posts, either by its left side bar, or view it in Mosaic / Timeslide / Flipcard option.
Aug 02, 2013 | Televison & Video
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Cable box-dvd/vcr- tv hookup problems
buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
May 17, 2009 | Philips Magnavox DVD/VCR Dual Player
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
DVD PLAYER
what kind of dvd player is it, is it for your home? car? and what kind of tv is it goin to? get back at me, jason
Dec 28, 2007 | Sharp 25H-M60 TV
Hookup
you can get a Y connector (it has 2 inpunt and 1 output) connect both audio's to the "Y" connector and then connect the "Y" connector to the tv and connect your video cable to the tv
Nov 16, 2007 | Koss KS4110 DVD Player
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
