Question about LG Flatron L1750S 17" LCD Monitor
LG Flatron L194WS 19" LCD
Im unable to set resolution more than 800*600
  • 44 Answers
Check the VGA card of ur CPU.
load the LCD drivers
also check it's refresh rate, are they enable, if not then the VGA card did not accept the LCD properly. load the lcd drivers seperatly...
Posted on Feb 08, 2008
Bad colour at LG L194WS-SF
Hello there,
Step 1: check all connections
Step 2: update graphic card Drivers
Step 3: Use the monitors controls to manually adjust the settings of the color
Step 4: Use the Graphic Card Software to Adjust the Settings of the color
thank you don't forget to Rate
Jan 25, 2011 | LG 22" FLATRON LCD Monitor
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
Xp os i make a misstake full resolution and screen is blank plz help me lg lcd 32 inch
reboot PC in save mode and set the resolution to 640 x 480 @60Hz, reboot in normal mode and reset the resolution to the native resolution of the monitor (you need to find out what that is in the monitor owner manual).
Mar 09, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Flatron LCD Montor to a Dell Dimension XPS T500
> out of date?
Are you sure that it is "out of DATE" ???
Reconnect your old monitor.
Set the screen-resolution to 800-by-600 at 60 Hertz.
Shutdown.
Connect the new monitor.
Reboot.
The new monitor will be detected, and will run at 800 by 600 at 60 Hertz.
Change the screen-resolution to some higher value that both the new monitor, and your older video-card, will allow.
Jan 02, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Analog- out of range
boot PC into safe mode, (pressing f8 on startup) then go to display settings and switch resolution to 640x480 (basic setting)
then reboot into normal mode, and then go to display settings and then choose an appropriate display resolution
this is caused when you replace a monitor as the old monitor ma have had different capabilities from the new
Feb 25, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My monitor goes black and does not come on to i turn the powe off
Dear Sir/Madam,
Reinstall the monitor drivers and right click the desktop go to Display properties->Settings->Check the Screen Resolution and select 32 bit color check the screen resolution is 1024X768 if it is not listed there will be the problem with driver software.
Nov 26, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Lg 19" monitor stuck in digital zoom
Did you try pressing the "auto reset" button on your monitor?
Newarz
http://visualtreats.googlepages.com/
Oct 11, 2007 | LG Flatron L1750S 17" LCD Monitor
Monitor not work
Try starting your computer in VGA mode (one of the options available from the menu you get if you keep tapping F8 as the computer starts up). In this mode the monitor should work well enough to get to the right resolution. Go to the display settings dialog (right click background and choose Properties, then the Settings tab), and pick the native resolution for your monitor (1280 x1024). Might be worth checking the refresh rate is ok as well before switching to the new resolution (press the Advanced button and the Monitor tab to check this).
Oct 28, 2006 | LG Flatron 995FT 19" CRT Monitor
LG Flatron L1750S 17" LCD Monitor Logo
2,479 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
