Its a 1993 acura legend 4 door with a v6. the engine turns over and over but wont start. we tried starting it with starting fluid, that didnt work. we checked for power to the coils and there is none. we checked the fuses also and they were all fine.
That sounds like a dead battery. The ticking sound is the relay (a type of switch) which enables power to the starter motor when you turn the key.
If the battery is weak, the relay will click, but there is not enough power to turn the starter motor.
i have the same year model its you main/starter relay new 90 bucks if you take the botom dash off and look right under"get out and look up" the left side and it is back/red and on the bottom of the housing "when u get a new 1 to avoid labour cost just unplug the old one and plug in the new one"its on the housing with other connectors and a silver bolt. hope that helps
replace de ignition module first.. if still wont start good chances is the crank sensor is located behind the timing belt.. my 94 legend use to do the same thing until i replace the crank sensor.. and also if u can afford i will suggest u to replace the main fuel relay too... all this is after u are 100 pcnt sure that ur fuel pump is working....
