Question about Konica Minolta magicolor 2430 DL Laser Printer
Konica Minolta Magicolor 2430 DL - Paper Feeding problem and Clicking Sound
Hi All
As I've explained, my printer makes a clicking noise (meaning a mechanical problem) and the printer fails to feed heavy paper although it could before. Any ideas what should I look first (apart from looking for a new printer)?
    Champion:
  • 214 Answers
Right now, i dont know about the cliking noise, there can be many things causing this. but for hevy paper open cover, take out PC drum, under that there is a take-up roller, pull the little knob in right side and then move it to the right side, then you can pull out the take-up roller, then clean the roller and the plate, whats under the roller. installit back. if thats not helping, then you have to take the roller out again, and cut off two plastic sides.
it shoult help.
Posted on Feb 09, 2008
  • Gary Hall
    Gary Hall Feb 11, 2014
    I can just about guarantee that your "Waste Toner" container is FULL! I had the exact same problem, changed it out, and it stopped immediately
Canon PIXMA MP510 problem with j feed
Is mechanical problems,gears blocated,you must be remove the covers and look attent the transport drive mechanism components.
Feb 16, 2013 | Canon PIXMA MP510 All-In-One InkJet...
X5650 Unrecoverable scan error. Does not feed the paper.
that sounds more like a mechanical issue. You might want to call Lexmark at 1-800-LEXMARK about the problem. Hope your printer is still within warranty. Hope this helps.
Jan 27, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
My Samsung CLP300 has a paper feed problem. When
Lift up the front of your machine about 4 inches with a book.
The paper will now feed easier.
Richard
Oct 27, 2009 | Samsung CLP 300 Laser Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer paper reloading
So the feeder woek sometimes, If you have a warranty, bring it back, if not , the printer might have something stuck in his mechanism or a bit of spread ink, open it and check for any weird thing, you can do some cleaning but the mechanism need some greassy spot so do not be too clean
then try a recommanded paper for the printer like 80g for example and no more than 30 new pages to begin.
You can test the printer when open, you just need to push a few switch or button to make it run also you will be able to see where the noise come from.
Dec 18, 2008 | Canon Pixma MP450 All-In-One InkJet...
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Won't feed paper
when you say ''heavy weight'' do you mean thin card etc.
Most printers dont like to use thicker paper. does it make a noise. like gears slipping or crunching when it is trying to feed. if this is the case, then the feed gears maybe worn.
Feb 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
May 07, 2007 | Brother MFC 7420 All-In-One Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
321 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
