Question about WYSE S10 (90210501) Network Terminal
Wyse PXE boot error
We seem to be having a lot of these S10 terminals in the past few weeks fail to boot with the same message:
PXE: No boot device present. Halting.
The error message comes up after normal use. They are simply used as internet browsing/word processing machines in the building, so no settings should be getting changed.
We have tried removing the network cable from the machine in hopes that it would skip booting from the network, but that did not work. Instead of the above error it simply states that it cannot find a network connection, and does not boot into the OS.
We have normally sent these out to Wyse to be repaired and/or replaced, however we have sent out over 5 in the past 2 months, and we're curious to see if there is any solution to our problem other than send them out for repair at Wyse.
  • debbie845 Dec 17, 2008
    We had a power outage yesterday. The Wyse did not come back on after the outage...message states No boot up device. Halting. Anyone with a solution? Thanks!
All Boot devices in BIOS may need to be set to "NONE". When shutting down, select "Shutdown and Restart the system, then hold the "Delete" key down while clicking the OK button. Keep holding the "Delete" key until system restarts in setup. Password that I was given is "Fireport". If that gets you access, then set all boot order configuration items to "NONE", then "Save Values and Exit". Hope it works for you as well as it did for me.
Posted on Dec 18, 2008
  • 25 Answers
Could it be that the flash drive has become dislodged or died? It is secured with a screw, and the connection itself.
I just tested on an S10, and it go that error when i dis-connected the flash module.
I am afraid that you wont be able to fix this yourself without invalidating your warrenty though!
Can't boot up without a boot disk
Your computer has been configured to try to "boot" by loading the Operating System from a network-connected "boot-server". Since you're _NOT_ likely to have such a "boot-server" in your home-network, the error-messages that you get are what are _expected_ when your computer is _NOT_ connected via the Ethernet cable to a 'PXE' (Pre-Boot Execution Environment) boot-server.
Enter BIOS-setup, and disable the "boot from network" option.
Mar 01, 2010 | Computers & Internet
Getting a message about shadowing my session
The program you are using is telling the terminal to accept a VNC request, as it will send date on the port open for VNC. So the terminal is asking you to accept the prompt to allow a remote machine to control your session.
You can set the program to ignore the VNC ports, so it wont get prompted. Failing that you should be able to change the terminals behavior to the requests by editing the wnos.ini to not allow VNC connections. I think that can be done from there. Check on the config generator for wyse terminals on technicalhelp.de to find the correct syntax.
Jun 23, 2009 | WYSE S10 (90210501) Network Terminal
Connection reset by peer
is this a citrix environment? have you just applied a rollup pack to your terminals?
You need to speak to Wyse!
Apr 27, 2009 | WYSE S10 (90210501) Network Terminal
Wyse S10 RPD to Server 2008
you have to buy 1 terminal license for you S10 also.
Apr 23, 2009 | WYSE S10 (90210501) Network Terminal
PC will not boot.
Hi , without explaining all that is happening ,your pc harddrive has failed.The pc is looking for an operating system but cannot find it.
Dec 08, 2008 | Toshiba Satellite A135 Notebook
Wyse S10 and Windows 2008 Terminal Services
The Wyse S10s require a firmware update to connect to Windows Server 2008. This is due to lack of support for RDP 6.1.
The update I've found to work best is 6.4.0.18.
The only way to get this update is to contact Wyse. However, I have deployed it on numerous clients (our entire base is S10s) and had great success.
Nov 12, 2008 | WYSE S10 (90210501) Network Terminal
Hard Reset
Youch, thats a pickle!!
Basically, because the terminal is in loopback mode when in the OS, you would need to find an up to date .i2d file, and for the S10, then try and re-image it with Wyse Simple Imager. This will use PXE and DHCP option tags to grab the device, and push an image to it.
Make sure PXE is first in the boot order in the BIOS, people often forget this!!
All the software you need (apart from the i2d file) is available from the Wyse website. When it comes to the i2d file, you will need to contact Wyse directly to get hold of this.
http://www.wyse.com/serviceandsupport/support/downloads.asp
Jun 04, 2008 | WYSE S10 (90210501) Network Terminal
Wyse S10 Power UP issue after hung-up.
pull out the power cord for 5 minutes than put back in and turn on
Jan 29, 2008 | WYSE S10 (90210501) Network Terminal
WYSE S10 (90210501) Network Terminal Logo
4,074 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
