Question about Cuisinart ICE-50BC 1.5 Quart Ice Cream Maker
Cool not cold
Ice cream does not freeze even after an hour no colder than when it went in
  • Fabio Bala Dec 02, 2008
    Exactly the same problem, it simply chill the ice cream mix, it seems is not cold enough to turn it into ice cream.
  • johnce May 25, 2009
    ice cream was like soup. it was my first time using it. literally just stirred the ingredients for 1 hour and came out like it went in.
I took mine apart and there is a cooling fan inside. It was broken so there was no air circulation inside. The fan is plastic and is a poor design.
Posted on Feb 22, 2010
Hate to ask but did you remove the shipping disk from underneath the bowl?
Posted on Dec 27, 2008
I have the same problem. I just bought the machine. I thought possibly that the machine was stored on it's side. So I waited 24 hour, the instructions mentioned. It still does not work. Does anybody have any solutions??? Thanks..............
Posted on Nov 10, 2008
  • 77 Answers
It could be the cooler deparment needs to be replaced
Posted on Feb 17, 2008
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Soft Serve Parts C713
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
Gets only cool not cold
the thermostat is supposedly right below the BLACK switch knob of the unit.
it should look like this if you open the unit up.
but before you open the casing, try to refer to CuisinArt's warranty terms even if you lost the proof of purchase for the unit.
good luck
Jul 27, 2008 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Why won't the freezer freeze the ice cream? It freezes around the outside of the cannister only.
According to White Mountain, this happens because the ice brine gets too cold. The procedure they recommend is as follows:
After you put your cream can in the tub and attach your crank or motor, fill the tub with ice and run for two minutes to cool the cream can. Then, put two cups of rock salt on top of the ice and let it continue to crank. After the ice level has dropped 2-3 inches, put more ice on top and another two cups of rock salt and let it continue to crank until the ice cream is done.
Sep 24, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Ice cream maker doesn't chill
The machine must be upright for 24 hours before using it.
If it was stored on its side or upside down you MUST wait 24 hours with the machine in the correct upright position. The 'person' who delivered mine made sure he tumbled it over and over again scanning shipping labels even though it said everywhere fragile and this side up.
If the machine does not work at cooling after 24 hours there is a problem and it should be returned.
Do not expect rock hard ice cream, but thick scoop-able medium firm soft-serve is easy to get as a result. A few hours in the freezer will harden it more.
Nov 08, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Wanting to make less than the 5 quarts that it holds, do I just reduce the recipe to the 2 quart instructions, will it freeze with that much less?
Why would you want to do all that work for LESS ICE CREAM???
In my experience, your ice cream maker will make any amount of ice cream up to its capacity. Remember, it is the salt that is the magic ingredient here ... that allows the ice water you are creating to get colder than 32 degrees F. Ice isnt really cold enough to freeze the mixture.
Sep 07, 2009 | Rival 8550-X 5 Quart Ice Cream Maker
Sorbet not freezing
If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
Hope this helps.
Aug 03, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
The bowl doesn't freeze in my freezer.
The noise you hear from you machine is provably just the mixer but not the compressor the bowl and the mixer has different cooling systems to check the you got to see your contractor kicking in when you activate the dispenser handle. reply to Art after check that
Apr 08, 2009 | Salton Ice Cream Makers
Tank won't freeze
The keys are to make sure the freezer is cold enough, and to make sure the bowl is level when it is sitting in the freezer. 24 hours is usually required, despite what manual says.
If all else fails, the freezer bowls are replaceable - you can order them from Cuisinart - if you are in-warranty, they may even be able to give it to you for free.
-tha Mp3 Doctor
Jul 08, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Vanilla Bean Ice Cream
makes 1 generous quart
4 egg yolks
2/3 cup sugar
2 cups half-and-half
1 vanilla bean or 2 teaspoons vanilla extract
1 cup whipping cream
In a bowl, beat the egg yolks until blended and mix in sugar. Heat the half and half, stir into the egg yolks, and pour into the top part of a double boiler. Split the vanilla bean and scrape its seeds into the cream and add the bean as well. Place over simmering water and stirring constantly, cook until the mixture is custard-like and coats the spoon. Remove from heat and refrigerate until cold, or several hours. Remove vanilla bean. If using vanilla extract, stir it in at this point. Just before ready to churn; stir in the whipping cream. Freeze according to directions for your ice cream freezer.
Sep 03, 2007 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
After a hour and half we still do not have ice cream
You need to make sure you continually refresh the ice as it melts, you also need to make sure you put salt on the ice. The salt makes the ice colder so that the ice cream can freeze up better.
May 29, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
Cuisinart ICE-50BC 1.5 Quart Ice Cream Maker Logo
389 people viewed this question
Top Cuisinart Ice Cream Makers Experts
Greg Cann
Greg Cann
Jay Finke
Jay Finke
Oloyede Monsuru
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
