Question about Electronics - Others
UNABLE TO ACCESS KINGSTON 1GB USB
When I try to log on to the USB Device I get the following error message:
Please insert Data Travellker II and run as priveledges user.
This does not happen on my laptop or any other PC. I can run other USB drives on the PCV I am now working on but not the Kingston. Grtaeful if you can find a fix.
  • 3 Answers
The laptop /desktop u r looging in to ur log on id should have admin rights.
If u have admin rigts then with the kingston u must have got an exe where u should be able to set public and private zone.
public zone can be access by any one but the provate zone requires password.
Once u click the exe u should be presented by the slider and password to set the public and private zone ..... Be careful if u r sliding it then this may result in data loss .
This is how u adjust whether u want public or private.
Slide it all the way and make it public and log off.
Posted on Feb 10, 2008
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
I got a Kingston 4GB Data traveller pen drive which when plugged into the usb slot gets detected and also opens fine but when i try to send in files to it it says : "Windows was unable to save all the data...
hi,
its not a issue , down load HP low device formatting freeware , then format your usb using that software , then reboot you computer inject the usb, again format your usb in windows , use FAT32, not ntfc to format, it will for mat then try to save it it will , its nothin your usb is affected by autoexe virus it will be find if you follow what i said,
thank you,
domnickr...
Sep 14, 2010 | Kingston 4GB Secure Digital High Capacity...
My 4GB pen drive store only 1GB data.when I sent more than 1GB data it shows system error.how can I solve it?
most likely the device ( pen drive ) is unable to use 4 gb of memory and thats why you have errors.
it could also be that you need to format the card correctly before use
Jul 31, 2010 | Kingston 4GB Secure Digital High Capacity...
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
Jun 22, 2009 | Kingston Technologies 512MB DataTraveler I...
Usb not recognised
the connector of you usb port of your unit kinston is need to re_soldering by using a soldering iron.or need to re-heat by hot-air unit.
kira_ryuk@yahoo.com
Jan 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Error Message re: KIngston 2G Pendrive
since the device uses usb power there is no way that you might be able to retrive data if the computer wants to format it.
Dec 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
Electronics - Others Logo
127 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
