Question about GPS
Convert a USB power/data to power only
Attached from a battery (4 x AA NiMH - it would be nice to add a 5V regulator) a standard USB power/data cable causes the GARMIN NUVI 205W GPS to go into USB MASS STORAGE MODE (for data transfer) just as if it was attached to a computer. The commercial car charger through the same mini-usb port allows the unit to work in navigate mode. How can I modify the cable so that the NUVI sees it as power only?
  • jeepsterza May 04, 2009
    I do not have the same, but a similar problem. Obviously not all the many connections in the car-power-connector are power related. Does anybody have a pin-out for the nuvi 710? I'm sure that one could unlock additional integration potential with this cable and pinouts.ru (usually very helpful) does not have this one.
I have found a partial fix for my problem at http://pinouts.ru/GPS/garmin_nuvi_power_pinout.shtml
This explains why a mini-usb "sees" data/power or just power. It has a different resistor between X and ground - the 4 pin. 200K ohm for data/power and 17.3 or 22K ohm for just power.
OK - where does this resistor "live" in the cable and what do I have to break to get at it to change it OR is there someone out there making a USB to mini-usb power only?
Posted on Feb 09, 2008
Just put a small piece of tape on the middle two pines on the larger usb side that plugs into the computer. just dont unplug the cable or you will have to put a new piece of tape on again
Posted on May 22, 2013
Microsoft Lifechat-LX-3000 , the wires got pulled out of the headset USB side , what colors go where ?
You can see if the wire is made corresponding to the USB 1.x/2.0 standard. (All USB cables should follow the standard, but many manufacturers don't respect this and use whatever cables they get cheap.)
The Pin-out and wire colors can be found here:
USB Wikipedia the free encyclopedia
(scroll down to "Pinouts", also provided below)
USB 1.x/2.0 standard pinout
1 VBUS Red (or orange) +5V
2 White (or gold) Data?
3 Green Data+
4 GNDBlack (or blue) Ground
Hope this helps!
Feb 17, 2013 | Microsoft LifeChat™ LX-3000 Headset
I tried using 3 AA NiMH batteries (total DC V=4.2, 1600mA) as a backup/charger for my HP Ipaq 612c battery. I inserted a resistor (4.7 ohms) in the circuit to reduce the current. The red light charging...
You built one of these too, eh?
Yes, there can be a problem doing this. First off, 3 AA batteries does not equal 4.2 volts, they are 1.2volt nominal so 3 * 1.2 = 3.6volts. When they are just off the charger, terminal voltage will be closer to 1.5v, so 1.5*3 = 4.5 volts.
Using ohms law, E=I * R, we can find your current as I = E / R or I = 4.5v / 4r7 as .95Amps (almost a full amp) that you would see worst case. The resistor is doing nothing for you.
The reason that the charge light blinks intermittently is because the charge controller (lithium battery, right?) is pulsing due to low voltage.
Try this: Take *6*, yes, 6, AA batteries, your choice of chemistry, and put them in series. That will give you a nominal (alkaline) voltage of 9v. Connect a low dropout 5v regulator such as an LT1117-5. Then you will be able to use your battery backup much more effectively.
On a different note, I used 4xAA (NiMH) and powered my ipaq 3650 directly. Worked great. Your mileage may vary though.
Aug 27, 2010 | Cell Phones
Which batteries?
Here is your answer.....
Battery Life: Good battery life for a camera running from two AA cells. The Nikon Coolpix 4600 uses two AA batteries for power, but its lack of a standard external power terminal prevented me from conducting my standard power measurements. It does seem to have pretty good battery life, particularly if you run it from high-capacity rechargeable NiMH cells.
Jul 20, 2009 | Cameras
Low battery indicator with new batteries.
AA alkaline batteries dont have the "power" that is require by the bigger better cameras to take and process pictures. NiMH is the best route.
Apr 21, 2009 | Olympus Camedia E-20N Digital Camera
LED Light on or off indicator
on my charger the red lights are only to tell there is power connecting especially when you have two battery's behind each other on the bottom of my charger there is a guide as to how long you should charge each battery as to size which are aaa 7hours max
aa 24hours
c 24hours
d 24hours
9v 24hours
hope this helps glenn............
Nov 20, 2008 | Duracell AAA NiMH Battery Charger with 4...
Car Power Unit
I'm not sure that there is a car charger available for the GPS 310. There is no external port where you could plug it in, the only thing you can do for power is take extra AA batteries with you.
Jul 02, 2008 | Magellan GPS 310 GPS Receiver
The usb cable are de-attached from the bord of my webcam
+Data
Green
-data
White
VCC
Red
GND
Black
BLACK BLUE BROWN are used as Ground
Apr 15, 2008 | Xirlink Promax Webcam
Choosing batteries
Your camera requires four AA size batteries. There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the Display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may vary based on the Alkaline batteries selected. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
External batteries
Sounds to me like you have a winning plan of attack. I did the same thing a couple years back, bought one of those 4XAA battery holders with a little slide switch and put a jack on the end of the wire...worked fine. Then I bought a 6V 1500 mAh rechargeable battery from Radio Shack that was made for r/c cars and such. It worked great too. Never had problem one with either setup.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
GPS Logo
3,271 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
