Hello,I have a Wirlpool sm8525079 top loaded washer that the basket spins way to slow during the rinse cycle. the coupler part is fine between the motor and clutch. could it be the clutch assembly?
its possible the ears on the top of the drive tube have worn alowing the basket drive block to slip and not turn the clothes basket with authority, or the basket drive block has just worn from overloading and needs replacing.. is easy to verify by looking.. best of luck, ttfn
check the 4 rubber cords at the top of the tub. If the washer has been moved they may need to be adjusted, you can see them by looking between the top of the tub and the top cover. You can turn them with your hand, and you may need to tighten them after.
Sounds like the coupler broke. This connects the motor to the trans. The part is only like 25.00 and labor is about 140. When it tries to spin if the basket doesn't move at all, then this is it. If the basket is really slow or easily stopped with your hands then the clutch/trans. could be bad. More times than not, it's just the coupler. These are made to break under heavy load, so it doesn't hurt anything else. They are just rubber and plastic and sometimes break for no reason. Push the lid switch with a pen or something with the lid up and try to spin to see what happens.
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
