Question about Fuji FinePix A310 Digital Camera
Locking up, no image in display
Hi, when I switch it on the lens comes out but the lcd display does not light up.
  • deankdx Feb 04, 2009
    when i turn on the camera, the lense comes out to focus, and shuts down completly.
    turning the dial to view images does nothing,
    removal of batteries for a few seconds allows the view images function to work, and the lense will retract when when turned off. but no other functions work.can view the function options and Disp on the playback function.
    is it ready for the bin? was a good camera otherwise
    Scholar:
  • 151 Answers
Have you tried pressing the DISP buttons? How about if you just browse through the pictures, does the LCD turn on? IF not, you have to have it checked or replaced...
Posted on Feb 08, 2008
Hi, when I switch it on the lens comes out but the no lcd display on power light falish 3 time and of, will play ok working this model...fujifilm A310
Posted on Sep 19, 2009
Why do my pictures display with lines across them? It looks like window blinds :(
Hi dear!
1. If you see like window blind on LCD when you camera switch on at camera mode. Check one more thing, press menu botton. You still see like window blind on LCD. and then you have defective LCD unit. Otherwise, you have shutter blades (not dust cover blades in front of lens) defect inside of lens unit assembly.
If LCD defect will be very inexpensive service and easy, otherwise, you bring to local repair shop. (very easy problem)
If Actual picture come out like window blind image,
then I want you load to computer and open the file.
You still see like window blind image. then 200% is the shutter blades not working properly inside of lens unit. Bring to local repair shop unless you are not able. Then I can give a little monkey job! using a tooth brush!
Hope You Luck! A Professional Camera Clinic Guy!
Apr 11, 2015 | Nikon COOLPIX Cameras
I have Panasonic Lumix DMC TZ3 camera and it suddenly stoped working when i switch on the lcd is black first i thought my lcd has problem but i can see images from my memory card very well only when i go...
Hello
First, if the camera turns on and the lens extends properly, toggle your "display" button until the screen image returns. (you can turn the display off via this button and is most likely the issue).
Otherwise, it would indicate a greater issue that would require the camera to be sent in for service.
Mar 10, 2011 | Cameras
PROBLEM WITH LENS/ LCD SCREEN
problem with the lens,not with the lcd,the image fomation is bad,so replace the C.C.D
Mar 05, 2010 | Sony Cyber-Shot DSC-H1 Digital Camera
Flickering image on LCD lens of my Canon S410
By the sounds of it you have a bad chip on your camera system board. If the image records okay and displays okay after the image is recorded. Other than having your camera repaired you may have to use your camera as is.
Jul 03, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
No audio and video comes out,but the player is reading the disc
Clean your lens with disk clear! Otherwise you want to change your lens in DVD player!
Jun 19, 2008 | LG DP170 Portable DVD Player
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Canon Powershot A60 Digi Cam
your problem isinternal circuit fault the recording section is not working. which is not giving any signal to LCD . you nee dto give itr in service centre. fault may also come in change over switch which is not giving connection to LCD. Sangita
Jun 22, 2007 | Canon PowerShot A75 Digital Camera
BLANK LCD SCREEN
The shutter in the lens is stuck closed. You need to take the camera to a shop where they will replace the lens assembly.
Nov 25, 2006 | Olympus Camedia D-580 / C-460 Digital...
Fuji FinePix A310 Digital Camera Logo
158 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
