Question about Market Forge Electric Table Top Kettle - 4 Gallon Electric Kettle
Kettle the inside of our kettle at work is turning green, something I have never witnessed before! We are a bit concerned as our building is extremely old and thus so is the pipework. Is it possible that limescale can present in this way or could this be caused by something else?
    New Friend:
  • 29 Answers
Today, best electric-kettle pots are made and arranged to take your kitchen furthermore you're home by tempest. Known for their protected and snappy way to deal with warmth up, these Electric-Kettles can lift off their vitality base which could be to a great degree convenient to you I have below one links their you can check review and service about electric-kettle and that may electric-kettle for you.
Posted on Aug 04, 2015
  • 552 Answers
Here is a link to instructions for a commercial kettle.
It tells how to clean and maintain.
I hope it helps.
http://www.blodgett.com/Literature/Manuals/Steam/KLS-E%20&%20KPS-E-man.pdf
Posted on Feb 09, 2008
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
Tip
Leakage problem at the bottom? Toastess International Kettle Model: TJK-103...
Leakage problem at the bottom…
Model: TJK-103 120V, 60 Hz, 1500 W
She was complaining that our kettle was leaking a bit at the bottom.
Warranty is over.
Here is what I did to fix the problem.
Unplug the kettle and empty it completely.
Remove excess residual water inside.
Remove the bottom cover by removing the screws holding it.
Gently remove the plastic ring screwed in place.
Now you will be able to put your hand inside the kettle and push the bottom out, toward the outside of the unit.
Take out the rubber seal and clean it. Ours was full of fine residue…
Gently dry it out and lube it with tiny bit of silicon.
Clean the inside part of the kettle before putting everything back together.
Make sure that you don’t squeeze any wires inside.
With a lot of patience, put everything back in place.
Make sure that the seal is perfectly installed. You can see it looking trough the plastic.
Kettle is now fixed and she is happy! ;-)
on Jan 23, 2008 | Toastess The Storm Electric Kettle
Why does the water taste funny after two . Months use
Usually taste change is created by a build-up of something inside the kettle or pot. Try the Baking Soda cleaning method:
  • Pour one cup of baking soda into the kettle.
  • Add water to fill
  • Heat the water and baking soda to boiling
  • Unplug the kettle and allow it to set for at least 10 minutes.
  • With a scrub brush or other scrubber, gently scrub the inside of the kettlepot. Be careful not to burn yourself.
  • Once it's all clean, wash with soap and water normally and rinse really well
That will usually get out any old residue that's affecting the taste
Mar 13, 2015 | Kitchen Appliances - Others
Why won't our BOSCH TWK8633 stay switched on?
You don't say how old your kettle is, but if it is less than 1 month, I would go back to the retailer where you purchased. Make sure you have your guarantee or proof of purchase.... Otherwise, going by past experience, kettles that won't stay switched on usually need de-scaling. Even if you can't see any lime scale in the kettle, there are sediments in the water that will build up over time & that can cause the element to overheat. This makes the kettle switch off prematurely or not switch on at all. In the UK, regardless of where you live, you should de scale your kettle at least once a month. If this doesn't work, you should still go back to the retailer, but if it's found that the malfunction uis diue to lack of de-sclaing, this isn't usually covered by the warranty....good luck!
Aug 09, 2014 | Bosch Styline Collection Kettle Twk8633gb,...
I have a 2085cl and it now produces a funny taste on my popcorn, what can I do to fix this?
If you are using chemicals to clean the kettle, that is what you are tasting.
You should only use recommended kettle cleaeners like Heatn Kleen, or Kleen Sweep from a popcorn distributor. Other cleaners will absorb into the carbon build up, and transfer a fowl taste. Old vegetable oil build up can also turn rancid over time and create a bad smell and taste.
Jun 05, 2014 | Gold Medal Kitchen Appliances - Others
Stopped heating
A part of the problem may be from the water supply. Water with minerals builds up in the percolation area pinching off the flow. You can put a cup of water, a cup of white vinegar, and about a teaspoon of Epson salts in the kettle and try cycling it. If it gets through the cycle, dump the mixture in something temporary to save. If it short cycles, try letting it cool 15-30 minutes and cycle it again. Keep in mind this mixture will not hurt anyone, but you may want to heat a couple kettles with fresh water before making anything for your significant other. That is, if it unclogs. If it doesn't, can't hurt to let it sit an hour and try again. Chemical reaction will clear it usually eventually.
Depending on the age of your kettle and the amount of water that gets on "that" plug on the bottom from filling can take its toll on the contacts. They can usually be cleaned up, buy DO NOT HAVE IT PLUGGED IN, when this is done. The base has a spring loaded bezel with the outer contacts on the outer part of the circle. Take a couple of Popsicle sticks on opposite sides to depress the cover evenly. Look around the outer ring for copper wire contact and rub it a might with a flat point jewelers screw driver (a little bit), if it looks fonky. If not, don't bother it. On the inside in the same area there's a copper tube. Look it over. It can be rubbed on the same way with your little screw driver. If the contacts look reasonable, don't mess with'em. Don't mess with those contacts at all, if the light comes on every time you press the switch down. Good Luck.
Dec 23, 2013 | Hamilton Beach 40870 Electric Kettle
Need new kettle for a Galaxy G14 popcorn machine?
Hello. If you want a new kettle you can contact here:
http://www.star-mfg.com/Scripts/ContactTechServ.aspx
If it just needs cleaning, there are a few products that will dissolve the build up, remember, don't submerge the kettle in liquids. It will have to be done slowly, and take a little time, oh yeah, and effort :)
If you contact the manufacture, they can recommend a cleaner to use.
Hope that helps, and thank you.
Feb 15, 2009 | Star G14-Y Popcorn Maker
Kettle
make sure there is no build up around contact points, sometimes you can add alittle soder to give it more better connection but you have to have some idea what your doing, good luck
Jan 21, 2008 | Hamilton Beach 40898 Cordless Electric...
Sapper alessi kettle
I bought new pitch pipes for my kettle and they came with directions. The directions from Alessi say to push the old ones out from underneath (part of the whistle that rests inside the kettle when it is closed) with a flat head screw driver. When installing the new ones, they say to only use your finger to push them in from the top, using only the eraser end of a pencil if you need to push with something. Mine were very loose, however. Also, the side with M1 or S1 etched into the brass part of the whistle should go lettered-end down into the brass tubes.
Nov 19, 2007 | Coffee Makers & Espresso Machines
Gas cooker on boat
Generally, black soot stains mean the gas/air mix has too little air. If you have an adjustment for the air mix, open it up a bit. Also (don't laugh)- small spiders love to build cocoons inside these gas/air tubes. That really messes up your flame!
Aug 20, 2007 | Iron Works Stainless Steel Gas Cooker (LP)...
Kitchen Appliances - Others Logo
457 people viewed this question
Top Market Forge Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Market Forge Kitchen Appliances - Other Expert? Answer questions, earn points and help others
