Question about Dryers
Hotpoint aquarius vtd00 dryer starts ok then slows down and stops
Hi, my dryer starts as normal then after about 2 minutes starts slowing down and making a grinding noise before stopping completely, but still sounds like its trying to spin (if that makes any sense)
  • 2 more comments
  • wolfington Feb 08, 2008
    Thanks for the very quick response, can i fix that myself or would i need to call someone in to do it?
  • dennis Feb 16, 2008
    my dryer works ok, seem like the drum has dropped off the front panel, is there something under the back end of the drum holding it up level and on the front? nothing has siezed and motor works fine, the belt is not tight enough to turn the drum because the drum seems to have dropped.
    my drum has come off the front and doesn't turn because the backend seems to have come off some kind of wheel and the belt is now not tight enough, although nothing else is wrong, is there something underneath at the backend of the drum that holds it up level and on the front panel?
  • Anonymous Mar 27, 2014
    after started starts to make a loud noise like a grinding noise
YOU CANNOT FIX IT YOURSELF.
THE DRUM IN THIS MACHING IS THE WRONG SHAPE FITTED IT HAVE HAD SAME PROBLEM, WAS ADVISED THAT ALL THESE MACHINES HAVE BEEN RECALLED CHECK IT OUT
HOPE THIS HLPS
Posted on Mar 14, 2008
    Novelist:
    Champion:
  • 244 Answers
Sounds like your bearings have gone at the back off your drum behind the small middle panel try turning it by hand if it starts scrapping straight away then u need to replace the bearings m8
Posted on Feb 08, 2008
  • peter gittos
    peter gittos Feb 09, 2008
    no u should be able to fix yourself all u need to do is go on ebay go into home and garden dryer parts type in what u need hotpoint bearing kit and it should come up with all the results find the cheapest with your model no: its not a hard job and it shouldnt take no more than about 30minutes cant remember if u need to re-rivet the bearings back on m8
Hotpoint aquarius vtd00 wiring diagram
For a wiring diagram, contact Hotpoint directly.
Sep 11, 2017 | Hotpoint Dryers
Hotpoint aquarius vtd00 dryer clothes getting stuck all the time how do I fix
hiis the rim of the drum seating ok or worn out because it will give u sharp edges its all i can think of take top off rotate by hand check rim allso try lifting drum if you have fair bit of play you need front bearing pads
Dec 28, 2013 | Hotpoint Dryers
How do you replace a belt on a hotpoint aquarius vtd00
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 26, 2010 | Dryers
HOTPOINT Aquarius VTD00 Model. The dryer is producing heat but the barrel is not revolving
hello, first thing to check is the long pin on the inside of the door make sure it's not snaped off, 2nd thing is the belt inside the dryer . if these are both ok then it's possible that the capacitor next to the motor could be faulty give a tap to see if the motor turns good luck
regards
shaun
Oct 08, 2010 | Dryers
Drive belt has snapped
Watch this video:
Jul 11, 2009 | Dryers
Runs slow then speefds up
If it is slow in starting, could be faulty start capacitor, slack or worn belt,overloading of course.
the capacitor is mounted near the motor, and is a round cylindrical tube about 4" long.
If u require any more info , then let me know.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint TDC32 Electric Dryer
Dryer runs but slows down then speeds up
There are no brushes fitted in the motor in these dryers..
More likely to be a worn belt, or possibly faulty start capacitor.,\which is located adjacent to the motor..
Thanks.
Tuble dryer not spining
sounds like your drum belt broke
Dec 01, 2007 | Hotpoint NWXR473EV Dryer
My hotpoint vtd00 dryer seems to have stopped drying
Have you cleaned the exhaust ducting? The duct that runs from inside to outside. Try that first. Sounds like your exhaust line is blocked. Also with the filter out get a flash light and look down the venting if alot of lint vaccum out. NOTE: Unplug the unit, wheather gas or electric.....and if it is a gas shut off the gas to the dryer before moving just in case something gets loose while moving. Hope this helps.
Nov 11, 2007 | Hotpoint NWXR473EV Dryer
Dryers Logo
450 people viewed this question
Top Dryers Experts
