Need help My copier is sawing E012,E020
    New Friend:
E012 drum problem
Posted on Jan 05, 2013
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
I guess I have to use my psychic powers to see what machine it is.....................................................................................
Canon ...........E020 toner feed problem
E012..................?????? ( not in the canon error code list........E010 & E011 Drive problem)
Posted on Feb 08, 2008
Please explain me the error code of Duplo DP A100 printer the error code is: E012 cordially thank you
You may need a maintenance kit . Check right side interlock It my be broken.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Nov 23, 2014 | Office Equipment & Supplies
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
Error
CLC1150 problem code E020 0181
what is this? The machine has been off/on and we also this problem
info@setobemmel.nl
Jan 31, 2010 | Canon CLC 1150 Color Copier
Need a services manual with codes and fixes
E000 : The main thernistor is opened.
E001 : Thermistor in short circuit.
E002 : SSR faulty
E003 :SSR and PCB faulty
E004: SSR in short circuit.
E005: Fixing web taken up.
E010: The main motor defected.
E012:Drum motor blocated.
E013:Wastw toner feedscrew faulty.
E014:Fixing motor defect.
E020:Hooper motor failure.
E032:PCB defect.
E061:Laser unit faulty.
E100 :The DC controller PCB malfunction.
E110:Laser scanner motor defect.
E121:M4 cooling fan defect.
E196: EEPROM faulty.
E202:Scanner home positin faulty.
E204:ADF controller faulty.
E220:Lamp inverter faulty.
E225:Xenon tube malfunction.
To reset in service mode press COPIER-FUNCTION-CLEAR-ERR.
Aug 11, 2009 | Canon imageRUNNER C6800 Copier
Error e012-0001 problem
It is a Drum Drive system over load/ or Drum Motor issue/ DC pcb issue. Need to check drum blades for all colors or if Dev. units are locked up.
Apr 03, 2009 | Canon CLC 1000 Color Copier
Canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Jan 13, 2009 | Canon CLC 1150 Color Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
252 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
