Question about Gigabyte GA-965P-DS3 (0818313003027) Motherboard
Usb fault motherboard doesnt recognise usb onboard but wen i plugin pci usb it does work
Usb not suppot
Posted on Mar 28, 2011
    Genius:
  • 1,601 Answers
Did you run the motherboard cd? The usb drivers are on it. Also, make sure they are enabled intthe BIOS.
Please let me know how this works for you.
thanks
Posted on Feb 08, 2008
What memory and processor use Q35T-GB
Socket Type: LGA775
Supported Memory: DDR
Onboard Video: yes
Onboard Audio: yes
Graphics Expansion Slot: PCI-E x16
PCI Slots: 2 PCI, 1 PCI-E x1
USB Ports: 6
VGA Ports: 1
This should be the homepage:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2654
Good luck
Mar 16, 2013 | ECS Q35T-GB Elitegroup Type Motherboard...
945GCT-HM Motherboard does not recognise my Sapphire HD-7750 graphics card
check primary graphics adapter setting in bios (should be pci not onboard) and check if the card needs a power supply connection
Jan 17, 2013 | Computers & Internet
Nosound
I am going to just have a few guesses at your problem as "nosound" doesnt really clarify it enough =]
If your onboard sound isnt working, You could try looking for an audio driver for this particular motherboard. Google "Intel D865GRH Onboard Sound Driver"
If you are using audio ports in a computer Case, make sure they are connected correctly to the motherboard, or use the audio ports on the back of the board.
Onboard sound does break on some of these older boards, Try using an external soundcard. (PCI or AGP) or a USB one. I picked a 7.1ch USB soundcard up off ebay for $8 and it works fine on all my old motherboards.
Hope this helps you, Best of luck.
Jul 11, 2011 | Intel D865GRH (KD865GRHLKPAK10)...
No video in onboard plugin
If the motherboard has an onboard VGA output - try that. But first remove the plugin video card from the computer and then check the onboard VGA output.
Nov 02, 2010 | MSI 7207-090(K8NGM2-NBP) Socket...
GA M61PME S2P wont recognise 7600gs
You have to select PCI video card in your BIOS setup
Aug 07, 2009 | Gigabyte GA-EG43M-S2H Motherboard, Socket...
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
Memory not recognisedrecognised
you can only expand to 2 gb think you have extended toomuch
Jan 10, 2009 | ASUS P5RD1-VM Motherboard
P4p800-vm pci slot is not recognising the add on card ( TV tuner)
There is no PCI-E slot on this motherboard. It has an AGP 8x slot and 3 PCI slots, but no PCI-E. Therefore, even if you could manage to get the PCI-E card physically into the slot it will never work.
Here is a link to the manual - http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Dec 30, 2008 | ASUS PCI Express Graphic Card
USB ONBOARD NOT WORKING
Hello there.
It sounds like you do not have the additinal USB patch which you can download and install from here http://dlcdnet.asus.com/pub/ASUS/misc/utils/S3USB.zip
The article for the patch is here, which addresses the problem with USB failing to work.
Please run this fix and your USB should be working, if not then please get back to us and we can try additional steps.
Hope this helps.
Jun 28, 2008 | ASUS P4S8X-MX Motherboard
Gigabyte onboard vga is not default... no pci card
What you can do here is remove the Battery on your mobo. This will reset the CMOS and then you should be able to access your CMOS as usual. :)
Dec 25, 2007 | Intel Motherboard
Gigabyte GA-965P-DS3 (0818313003027) Motherboard Logo
109 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
