Question about Fuji FinePix F460 Digital Camera
When Zooming picture it produces blurred or fuzzy picture
When I zoom in all of my pictures are fuzzy. When not using the zoom the pictures are perfect.
    Scholar:
  • 151 Answers
This is when zooming through your camera LCD I presume? For small screens usually banding and pixelation is common, if this happens also when the picture is zoomed in on a larger monitor like on your computer then the resolution you set for your camera is low. You can check for the camera setting and increase the resolution from for example 1024x768 to a much higher value and the fuzinnes (blur) will disappear altogether...
Posted on Feb 08, 2008
How can I keep the picture sharp when zooming in macro
When you zoom in macro with a Coolpix camera, you must change the camera to subject distance to compensate because as you zoom in and out, the depth of focus of the lens changes dramatically.
Jun 10, 2014 | Nikon COOLPIX Cameras
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Not clear picture in zoom while still photo taking
hi there
know you must adjust the zooming for the right range on the camcorder to accept the long and the short distances , so if you but it in the long distance and take apic on shrt distance it will came blur pic .
good luck
Jan 19, 2011 | Sony Handycam DCR-SR68E Camcorder
What is the cause of having blurred picture when zooming?
its probly due to the distance off the zoom lens and the focus lens
cause by a focus motor defective or miss aligment in whole lens assembly du to a choc or so...
hope that will help
regards alan
Oct 06, 2010 | DSC Video Cameras
My camera is showing blurred pictures when taking pictures help
Try reseting all menus to default, then try again to test.
Make sure the lens is clean.
Do the menus appear clear?
Has the camera ever been dropped or had any other damage? This could get the lens out of focus, and would need repair.
Does blurring happen when zooming or when taking a picture of any kind?
Sep 09, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Macro in sony W170 digital camera
The resolution of the photo you take determines how grain shows up as you zoom into the Photo, So taking a 10 megapixel photo on optical zoom or no zoom will give you a sharper picture than when you use both the optical and digital zoom to grab your picture. The digital zoom uses the centre of your CCD picture imager rather than the whole CCD so with less elements to your picture when you take it gives you blockiness sooner when you zoom in on the image. I am guessing your friend has digital Zoom turned off in settings to prevent the Graining showing upon magnification. Good light and a steady camera will give you the best results.
Dec 05, 2017 | Sony Cyber-shot DSC-W170 Digital Camera
Can't take pictures.
try zooming in on a object and see it it get clearer. the problem is your zoom lens motor is stuck or malfunctioning. This is a very common problem with digital cameras. sometimes you can take compressed air and blow around the lens and clear the blockage or lightly tap the camera lens down with it off to free up the focus gear. if it does now work it then needs tobe serviced or repaired. I had the same model last week for the same problem. That lens had tobe replaced. but try that first and see if it helps.
Apr 04, 2008 | Olympus FE-190 Digital Camera
Blur image
I am having a problem with blury pictures. Every one I take is blury and it also seems the flash wont go off. Now the pictures are blury even in the daytime. Anyone that can help me please do!!!!
Mar 26, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Night time pic mode
The one thing I have noticed about the DV179, is that it takes poor quality photos and video, unless it is in pure sunshine... :)
Yes, zooming in does distort the pic's, so be sure to put the stabilization mode to 'on', this does help a bit.
Dec 27, 2007 | Jazz DV-179 Digital Camera
Won't focus when zooming into the subject
It seems that the lense element which mooves while zooming the camera is stucked. normally this happens when the camera suffers a heavy jery, may be by dropping the camera. Resulting into disalingment of the lense assambly. You will need the help of repair shop to solve the problem.
Sep 15, 2006 | Olympus Camedia C-765 Digital Camera
Fuji FinePix F460 Digital Camera Logo
104 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
