Tappets making noise on a 4Y petrol engine 2.2 may be caused by a few different things. Here are a few possible causes and solutions:
- Lack of oil pressure - If the engine is low on oil, the oil pump may not be able to provide enough pressure to properly lubricate the tappets. Check the oil level and top it up if necessary.
- Worn tappets - Tappets can wear out over time, especially if the engine has high mileage. Worn tappets can cause noise and can be replaced.
- Loose tappet adjusters - Tappet adjusters can become loose, which can cause noise. Tighten the adjusters according to the manufacturer's specifications.
- Valve clearance - The valve clearance may need to be adjusted. if the clearance is too tight or too loose, it can cause noise.
- Dirty engine - If the engine is dirty, the tappets may become clogged with debris, causing the noise. Clean the engine thoroughly to remove any debris.
- Oil Quality - If the oil you are using is not of good quality or if it is too thick, it will not lubricate the tappets properly, causing the noise.
It's important to follow the manufacturer's instructions and use the right tools and equipment when working on the machine. If you are not familiar with the mechanical systems, it's best to take the vehicle to a qualified mechanic to diagnose and fix the issue.
What exact engine is it? The 2TZFZE?
