Question about Dryers
Miele novotronic 510 keeps tripping fuses - Dryers
  • biddyS Feb 09, 2008
    The Meile trips soon as you press start on high heat and then after a few seconds it trips on low heat.
  • 16 Answers
Possibly the heater bank. Try running it on cool air, still same problem, then you will need to post more info. IE. Does it trip when you switch it on via the button?
Does it trip as soon as you press start?
Does it trip after a seconds of mins after you start it?
Posted on Feb 08, 2008
My Miele Novotronic T650c works for some 5 minutes or so and then trips the fuse. What is likely to cause this and how to fix it?
What fuse is it tripping? If it is a fuse that is inside, you need to check the components that are present. Something is getting hot and failing. It could be a voltage regulator, IC capacitor, or transformer.
Oct 28, 2013 | Washing Machines
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Miele T230C dryer keeps tripping out after only a few seconds?
Mostly likely cause is the heater element part no. 6138580. To ensure this does not happened again 1. Ensure appliance is situated in a cool room with ventilation (If room to hot it will not condense)
2. Ensure metal heat exchanger at bottom of appliance is rinsed regularly both long way and width ways.
Feb 01, 2011 | Miele Novotronic T230C Electric Dryer
Miele t494c start and then trip the fuse on main fuse box what is the problem
Had exactly the same problem. First, I tried with changing the plug - worked ok, but wasn't really the right solution. Then, cleaned with a high pressure washer (like the one you wash your car with). The result: no more problems!
Good luck.
Oct 12, 2010 | Miele Novotronic T240 Electric Dryer
Dryer runs but dosn't heat any ideas would be appreciated
Visually verify household fuse blown or a circuit breaker tripped.
The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuse or reset the circuit breaker.
If the problem continues, call an electrician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 16, 2010 | Miele Novotronic T220 Electric Dryer
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
Fuse Box
there will be a glass fuse on the power board of the washer it might have cover over it good luck
shaun
Aug 14, 2009 | Miele Novotronic W1918A Front Load Washer
No heat out Miele T234C dryer.
Most likely fault is filters have been clogged and tripped the safety stat on rear of appliance. Wash filters and replace stat Part No. 5432530
Jun 26, 2009 | Miele Novotronic T230C Electric Dryer
Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 21, 2008 | Miele Novotronic T220 Electric Dryer
Dryers Logo
146 people viewed this question
Top Dryers Experts
Marvin
Marvin
