Question about Paradyne (6211-A2-200) Router
How to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I have configured paradign modem adsl2 6211-A3-304 in ppoe mode for BSNL Dataone Broadband connection.
I want to know how to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection.
  • 61 Answers
I belive with this modem you will:
1.Access the interface, generally http://192.168.1.1/
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Posted on Feb 09, 2008
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
Dataone broadband siemens adsl c2110 modem driver
Am I correct in asking you whether you are using a bsnl broadband....???? If so you don't need modem drivers. All you have to do is configure a broadband connection from your network connection wizard with your username and password. Good Luck
Jan 08, 2011 | Computers & Internet
How to cofigure my Dlink 502T modem for BSNL connection at chennai
If you want to connect and disconnect at your ease, the following steps will guide you through setting up a internet connection in windows using username and password whenever you connect.
Have a good time...
Step 1: Initial LAN Configuration First connect all the equipments to your PC. Details about this is probably given on the manual
Now on windows go to control panel -> Network Connections
Select “Local Area Connection” and right click it . . . Select Properties
Select TCP/IP in that box ->properties
Enter the details as follows
Set IP Address As 192.168.1.29 Subnet Mask As 255.255.255.0 Default Gateway As 192.168.1.1 Preferred DNS 208.67.222.222 Alternate DNS 208.67.222.220
Save settings and restart the computer.
Step 2: Settings for Modem Make sure the Power LED, Link LED and USB/LAN LED are on/blinking Open your browser (preferably Internet Explorer ) and goto http://192.168.1.1/ Input as follows USERNAME : admin PASSOWRD : admin
Now goto Setup Tab then click on new connection (left side navigation frame/panel)
Now fill the details as follows Name : BSNL
Type : bridge
Sharing : disable
VLAN ID : 0
Priority Bits : 0 Encapsulation : LLC Select LAN : LAN GROUP 1 PVC : new VPI : 0 VCI : 35 Leave all others at default values Then click apply The go to TOOLS tab Click “system command” (left hand side) Click “save all”
Apply and restart the modem.
Step 3: Setting up Internet Connection Dailer in windows Now goto Control Panel->Network Connections Create New connection (and a wizard will pop up)
Click Next
Connect to Internet(Select the radio button and click next)
Setup My connection Manually(select it and click next)
Connect using a broadband connection that requires a user name and password (select it and click next)
ISP name (type something, anything and click next)
Type in the User name and password given to you from BSNL in the specified columns (and click next)
If you want to add a shortcut of connection to desktop, check that square box and click finish.
Double Click the Icon in the desktop to connect to the BSNL Dataone broadband connection, and either double click the same icon or right click the system tray icon to disconnect from BSNL Dataone broadband connection.
Hope this will help you.
Feb 11, 2010 | D-Link Computers & Internet
I hv a netgear wireless adsl modem and i m using bsnl broadband connection can send me the settings to configure the modem at my email id mehtaankur3@gmail.com
TYPE-I Modem Configuration - Huawei SmartAX MT880 Modem / SmartAx MT882 ADSL Modem Configuration
SmartAx MT880 ADSL Modem has One ethernet Port.
SmartAx MT882 ADSL Modem has One ethernet Port and one USB Port.
Set your computer IP address as 192.168.1.2
( If you are using USB port, install USB driver first)
Open Internet Explorer in the Address bar type the URL http://192.168.1.1
You will be propted for Username and Password.
Username: admin
Password: admin
Click on Home
Click on WAN setting
Your WAN Setting should be as follows:
PVC No.: PVC0
Wan type: PPP
Connection Type : PPPoE
VPI / VCI : 0/35
Default Route : Enabled
Username: yourusername@dataone
Password: yourpassword
Use DNS : Enabled
Click on Apply.
You will be asked to save and reboot.
Select Yes
Once your modem is rebooted , the summary page will be displayed .
The "Green" status of PVC0 status indicated that you are now connected. (in Summary page)
SmartAx MT882 ADSL Modem ADSL LED will turn 'Orange' from 'green' when succesfully connected
Sep 15, 2009 | NetGear WGR614 Wireless Router
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username (john_citizen@optusnet.com.au) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
My dataone WA3002G4 (BSNL) modem is not connecting to internet
You need to configure the pppoe connection in the modem.
Jul 08, 2009 | Computers & Internet
This sounds like you need to set up your main gateway or WAN port settings on the datatone to match what your ISP provides? Is it possible to get suggested settings from the ISP?
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
Bsnl dataone modem driver + usb for UT 300R2U +
Here is BSNL Broadband UT STARCOM-UT300R2U MODEM Driver For USB download and install the driver through device manager
Download Link
http://freecomputercourses.blogspot.com/2009/06/download-bsnl-data-one-usb-driver.html
Apr 04, 2009 | Computers & Internet
BEETEL 220BX ROUTER
First login to your Router using default username and password
2. Click on WAN on the left side menu
3. You'll have options to add or remove configurations.
4. Please select and remove the bridge config as BSNL does not support Bridge.
5. Please click edit on the existing PPPoE Airtel Configuration
6. Set the VPI=0 and VCI=35 (for Airtel it would be 1,32) and click next
7. Select PPP over Ethernet (PPPoE) and encapsulation type: LLC/Snap Bridging and click next
8. Enter the following details:
PPP Username: Your bsnl username (no need to add dataone.in)
PPP Password: Your bsnl password
PPPoE Service Name: DataOne
Authentication Method: Select CHAP
Click Next
9. Check the Enable IGMP Multicast Option
Check Enable WAN Service Option
Enter the Service Name as Dataone
10. Click Next and Save. You should also save and reboot your modem.
If doing the above does not works, check if you have anything set Under TR-069 Client and remove all entries in this section however it may not allow you to save so you may just put the ACS URL as ( it won't accept this field to be blank so just enter any thing, I entered http://bsnl). Save and reboot the router. Should be online now.
let me know if anyone benefited from the above information - abialexin@yahoo.com
Jan 14, 2008 | Computers & Internet
Paradyne (6211-A2-200) Router Logo
1,561 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
