8051 microcontroller I require to transmit data from an 8051 microcontroller wirelessly. What method could i use? My conditions are that the module to be connected with 8051 be cheap and consume low power.
    New Friend:
You have couple of option here, either you build your own amplifying circuit and antenna to the serial port or you use existing RF module.
applied electronics engineering
Posted on Oct 24, 2015
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Well an 8051 has a built in serial port BUT is VERY sloooow.
1. how far?
A.short range you could use blue-tooth.
B. longer range: There are some wireless modules in Nuts&Volts(magazine)
C. go with a serial /ethernet adapter (very small) and then use a air card or cell phone..
FINS
Posted on Feb 11, 2008
2005 volvo xc90 will not stay running, it is giving a code of U0073 generic control module communication bus"a" off. .we have put in new crank sensor. the maf sensor is not the problem
Do you know what a serial data communication network is ? All the control modules on your vehicle share info on it . It stead of hard wiring all the componets on the vehicle they use control modules and a data network . U codes are problem codes assoicated with these networks . U0073 generic control module communication bus"a"OFF Has nothing to do with engine sensors ! Condition
The control modules transmit and receive information via a standardized serial communication method - CAN (Control Area Network).
The diagnostic trouble code (DTC) is stored if the control module detects that:
  • The control module does not have contact with the controller area network (CAN).
  • Incorrect value runs longer than 10 seconds.
The control module's test for the diagnostic trouble code (DTC) starts in the event of:
  • Starting the control module's CAN communication.
Note!The control module can only detect the fault once the test has been started and the diagnostic trouble code (DTC) is stored when the conditions are met. In the event of system communication problems, it is not possible to communicate with the control module. Therefore it will only be possible to read off the fault if it is intermittent. Substitute value
  • None.
Possible source
  • Open-circuit in terminals.
  • Damaged Parking Assistance Module (PAM).
Fault symptom[s]
  • Parking Assistance System, malfunction
  • Information lamp is on
  • Message in information display
A shorted module will cause the data bus to short and cause no start condition . You best bet , take it to a qualified repair shop . How to Diagnose Controller Area Network CAN
Jan 06, 2017 | 2005 Volvo XC90
Wiring diagram for code u0107 2004 avalanche
Do you even know what DTC U0107 involves ?
DTC U0107
Lost Communications With Throttle Actuator Control (TAC) Module
The throttle actuator control (TAC) module and the powertrain control module (PCM) communicate via a dedicated serial data circuit. This serial data circuit is separate from any other serial data circuit on the vehicle. Accurate transmitting and receiving of serial data requires not only good circuit integrity, but also adequate system voltage. This diagnostic test monitors the accuracy of the serial data transmitted between the TAC module and the PCM. If the PCM detects a loss of data or invalid data, this DTC sets.
Diagnostic Aids
Important: Reprogramming the PCM may cause a communication error between the PCM and the TAC. If the PCM detects a communication error, DTC U0107 sets. Clear any DTCs from the memory that may have been set by Reprogramming.
• DTC U0107 sets if the battery voltage is low. If the customer's concern is slow cranking or no crank because battery voltage is low, ignore DTC U0107. Clear any DTCs from memory that may have set from the low battery voltage condition.
• DTC U0107 sets when there is a short to B+ on the TAC module ground circuit. Inspect the fuses for the circuits that are in the TAC module harness--i.e. cruise, brake. An inspection of the fuses may lead you to the circuit that is shorted to the TAC module ground circuit.
Replace the TAC module. Refer to Electronic Throttle Actuator Control Module Replacement .
Did you complete the replacement?
Nov 20, 2016 | Cars & Trucks
TROUBLE CODE 2004 ISUZU U0107
Usually requires a new throttle actuator which may only be available as part of a throttle body assembly
Aug 27, 2016 | 2004 Isuzu Ascender
What is p0053 on a 2005 buick
Take the vehicle to Auto Zone or one of the other auto parts dealers and they will check it for FREE. They can advise you what to do.
0053 HO2S Heater Resistance Bank 1 Sensor 1
p0305 Cylinder 5 Misfire Detected
p0449 Evaporative Emission Vent Valve Solenoid Malfunction
u0107 Lost Communication With Throttle Actuator Control Module
Aug 23, 2015 | Buick Terraza Cars & Trucks
How do I find my SSID?
The SSID of a wireless network is determined by the wireless access point (AP) that you are using. Some AP's have a label on the bottom that give the SSID and Key for that particular network. Some AP's broadcast the SSID and that can be read off the air when you attempt to connect. Those are the 'available' networks that show up in the wireless network list. If you are trying to connect to a network that is not your own, you need to get the connection data, including the SSID and network key, from the person providing the network. There are open networks that broadcast their SSID and don't require any key, but those networks are not secure and data transmitted on them can be stolen.
Dec 04, 2014 | Tablets & eReaders
Source code in C language for finding the speed of a vehicle using 8051 microcontroller
if this is a europeon market vehicle then no chance encrypted software ,but it can be done by by pining the two wires from the sensor and reading the output voltage direct from the sensor ,as its only an induction coil after all ,
Dec 20, 2010 | 2003 Mini Cooper
I m looking out for program with 8051 microcontroller automatic bell
http://www.8051projects.net/downloads117.html
u can download the program from the given link.....
Mar 17, 2009 | Computers & Internet
Keil compiler
ya keil is a software which used for making hex file for microcontrollers and after that we insert this file to microcontroller by assembler .in keil you hv to use a c similar language.i am expert of embeeded system if u hv any further quiery then u can call me also at 9811613568
May 19, 2008 | Computers & Internet
No wifi connection
connect by cable long enough to complete the setup
type this address in your browser
http:\\192.168.0.1
which should start the routers webinterface you can navigate thru the Wireless settings ,s et channels etc
and copy them to the pc that you are trying to connect,
WEP - wireless encryption protocol - a method of scrambling transmitted data for security - both ends of the link have to have the same code key or they wont talk to each other
Apr 29, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
629 people viewed this question
David Payne
David Payne
