Question about Vacuums
Broken upright locking mechanism
This machine has a locking mechanism that locks it into the upright position. Yesterday this broke and a small piece of plastic flew off. I know I can buy replacement feet but having taken the foot off it does not look damaged, is there anywhere else I should look.
  • 2 more comments
  • Just Me Here Aug 03, 2008
    I have a Biselle 3760-1 and my son ran into the vacuum cleaner in the dark and I have the same problem in that there were small pieces of plastic on the floor and the unit will not lock in the upright position. If is is a pedal problem, where do I purchase a replacement as this should be cheaper than bringing it to a service center. My internet search found no replacement pedals.
  • Anonymous Aug 06, 2008
    Eureka 4870 the locking mechanism that keeps the handle portion of the show upright is broken. A little piece of plastic from the foot pedal must be gone and the foot pedal doesn't seem to want to hold the handle in place.
    Would love to order the part and get instructions for repair.
  • Mike6490 Aug 14, 2008
    Same problem with a Sharp 12txt7. The pedal does not engage or hold. How can it be fixed?
  • jburlis Nov 26, 2008
    Same problem here... sounds like a bad design! Great vacuum though.
  • 126 Answers
I need to know what brand the vacuum is. Various brands have different ways of locking the handle, but most incorporate a pedal that engages the handle. It sounds like you will have to replace the pedal. I hope it's not the handle portion. That becomes more complicated and expensive to replace.
Posted on Feb 08, 2008
What can I do to fix Panasonic vacuum MC-V7395 that will not stay locked in upright position?
Most vacuums have plastic tabs and a plastic mechanism of some sort to that will engage those tabs to make it stay upright.
I am suggesting either the tabs are worn down, or are broken off, or maybe the locking mechanism is broken.
These parts are most often not replaceable, unless you can find an identical machine with these still good on it, and swap whatever parts are necessary to fix it.
Machine is a "throwaway " model.
When it breaks, you are expected to buy a new one.
God bless your efforts.
May 02, 2016 | Panasonic Vacuums
The vacuum handle won't recline. Everything else works great, how do I fix it?
It sounds as though either the pushbutton may be broke or out of alignment. The recline works by pushing the latch pawl out of the locked position to allow the handle to recline. I have the user manual link and while it does not have that particular maintenance item the beater bar disassembly should let you see the mechanism to see if it is broken.
http://www.eureka.com/FileLibrary/e3d6977195674480857fbdfd0948b1a6/en_88151_OwnersManual.pdf
Oct 16, 2015 | Eureka AS2030A - Airspeed ONE PET Bagless...
Dyson DC28 Air Muscle Vacuum that is stuck in upright position
This turns out to be an easy fix.
First, get some graphite lube.
Lay the vac on it's 'face'.
1) On the underside of the vacuum, there is a 1/2" wide 'groove" in the motor housing, that runs up the centerline of the machine. Follow this groove from the front of the machine towards the back. As you follow it 'up' into the machine, the groove will 'end'. Just past this point there will be a small black plastic piece with little 'ears' that is resting in another groove that continues just past the point where the first groove ended. This is the upright position lock that isn't releasing. (I've painted the 'ears' red in the attached photo)
2) Using a screwdriver, or butter knife, etc, gently lift this piece out of the groove. The vacuum head should now easily tilt down like it should.
3) Flip the vacuum over onto it's 'back' and you will be able to see the grooves, now visible on the front of the lower head. Apply the graphite to the smaller (upper) groove and try working the unit in and out of the upright position several times to work the graphite into the locking mechanism
Feb 08, 2010 | Vacuums
Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 will not lock into upright position
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square hole basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Jul 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Handle wont go to upright position
The red pedal has slipped out of position. On both ends of the red pedal you'll see metal rods (the axel of the pedal). On one side you'll see the metal rod sits into a long groove, on the other side you'll see the metal rod sits into a round hole. They both have to be in the long grooves so you have to reposition the rod that's into the round hole by pulling it out and sliding it back into the long groove above the round hole. You'll now be able to bring the handle up and lock the machine back into the upright position.
Jun 17, 2009 | Dyson DC25 All Floors Bagless Upright...
My Bissell will not lock in the up-right position
Possibly the slider release is broken and needs replacement.
Jul 03, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Upright lock broken
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559827
Generic problem for all Vacuums
Upright lock broken
Posted by diamond8990 on Apr 30, 2008
Upright lock broken
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Not knowing the brand name and the model # it sounds to me that you have a broken handle release if that is what you are referring to as “Upright Lock Broken” – the handle release lever keeps the hand staying up and in the upright position. So include @ least the brand name and or the model # and I can try to further assist you. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Problem with wheels
If the belt is over a year old, it should be replaced. This is normal maintenance and is often overlooked. When the handle is in the upright position, it will appear the the height adjustment is not working. What's actually happening is that the height adjust is easily moved so you can make any adjustment you want. When the handle is pulled back, the front of the machine will lower to that setting and lock, so it will not adjust itself while you are vacuuming. If you wish to change the setting, you have to return the handle to the upright position, or you can lift the front of the machine with your hand, taking the weight of the machine off the wheels and this will allow you to slide the adjustment to another position. It is possible that the adjustment mechanism has come apart. It is comprised of three separate components. It would be very difficult to explain it here and should be addressed by someone familiar with this model.
Jan 12, 2008 | Hoover U5264-930 TurboPower Bagged Upright...
Vacuums Logo
386 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
