Question about Car Audio & Video
How to remove the door trim in a peugeot 206
I need to remove the driver side front door trim of my peugeot 206, 2002 model, in order to get to the stereo speaker so I can examine it so I can fix it or replace it.
Does anyone have any advice as to safest way to do it without causing any damage to door or trim?
Any advice greatly appreciated.
Carmelo
  • carmelo13 Feb 11, 2008
    Your advice gave the little nudge I needed to help me decide it is better to let a professional deal with it at this point, perhaps next time I will have learned some tricks on how to do it myself with out causing any damage to the door trim.
    Thank you, Carmelo13
    Scholar:
  • 151 Answers
The safest bet is to have a professional do it for you. However careful we are, we might make some mistakes doing so. Although you can always have the professional take a look at it the first time, then you can do it yourself the next time.
Posted on Feb 08, 2008
How to replace door lock cylinder drivers side 2002 x-type jaguar.
From inside the door trim. They are $340 new!
Door Trim / Card Removal, Jaguar S-Type R STR - YouTube
? 2:27
https://www.youtube.com/watch?v=PIl_Fsy7BUk
Apr 9, 2015 - Uploaded by Jag TV
This video shows you how to remove your interior door trim / card from a Jaguar S-Type R STR. ... I DONT ...
Drivers Door Handle Help - Jaguar Forums - Jaguar Enthusiasts Forum
https://www.jaguarforums.com > ... > Jaguar Models ( Modern ) > X-Type ( X400 )Jan 23, 2011 - X-Type ( X400 ) - Drivers Door Handle Help - Hi all, im having issues with my drivers door, the quick link posted by JimC64 helped, but the real issue. ... I have a 2002 2.5 sport if that helps. Thanks in ... Disconnect the front door exterior handle connecting rod and the door lock cylinder connecting rod. 4. S-Type 'HOW TO' Guides - Jaguar Forums
23 Sep 2017
How do I remove / replace door lock? X-Type Rear Door?
30 Apr 2011
Drivers door, outside handle removal - Jaguar Forums
27 May 2010
More results from www.jaguarforums.com
replace door lock cylinder drivers side 2002 type jaguar Google Search
Mar 12, 2018 | Cars & Trucks
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
How can i get rear inner door panel off of a peugeot 206 52 plate
remove two screws from armrest (usually covered by small plastic insert) prise out trim from door handle, gently ease panel out from bottom and slip upwards to release from window, once loose if car has electric windows disconnect wires.
Jul 11, 2014 | 2003 Peugeot 206
Need to intall new front exterior drivers side door handle on a 2002 Hyundai Elantra GLS
remove the interior door trim and you will see small nuts holding the handle onto the outer door skin. Remove any rods /clips and undo the nuts and the handle will come out.
Mar 18, 2014 | Hyundai Motor 2002 Elantra
How to replace front driver door hinge check strap
a lot of door check straps only use a rolled spring pin. If this is broken and you can remove the door trim it will be fixable mostly.
Jan 13, 2013 | 2001 Peugeot 206 1.6
I have a peugeot 206 got knocking noise from drivers side front when driving
sounds like wheel bearing, jack wheel up, an see if there is any free play, by trying to move wheel side to side
May 16, 2012 | 2004 Peugeot 206
How to remove front dopr panel on 1995 Lincoln Town Car
Front Door Panel - Town Car - Removal
CAUTION: To avoid breakage of door pull cover(s), insert a screwdriver diagonally between pull strap and chrome bracket. Snap out both sides then remove.
Snap out two door pull strap retaining screw covers. Remove screws.
Remove two screws on front and rear side of front door trim panel.
The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
NOTE: Do not use front door trim panel (23942) to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
Remove window regulator control switch housing from back of front door trim panel . Lift up housing, remove retaining screws and disconnect all connectors.
Disconnect driver seat regulator control processor switch (driver door only) if equipped.
Twist out interior lamp wire assembly and remove the front door trim panel.
Installation
Ensure plastic watershield is secured to door panel.
Position front door trim panel to door. Connect interior lamp wiring.
Position the window regulator control switch housing and connect switch connectors. Install the retaining screws.
Connect driver seat regulator control processor (14C708) (driver door only) if equipped.
Align door lock side to its mating slide on the sheet metal (front doors only).
Snap in front door trim panel. Ensure all retainers fit properly.
Install two retaining screws on front and rear side of front door trim panel .
Install two retaining screws and pull strap covers.
Good luck Remember rated this).
May 31, 2010 | Lincoln Town Car Cars & Trucks
Need to pull the panel off driver side door of 2004 ford f150
SECTION 501-01: Body System — Interior 2004 F-150 Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 02/17/2004 Front Door Trim Panel adobe.gif Printable View (229 KB) Removal and Installation
NOTE: LH side is shown. RH side is similar.
  1. Remove the front door speaker. Refer to Section 415-00.
  1. If equipped, remove the window regulator handle.
    1. Separate the handle cover from the handle.
    1. Remove the screw.
    1. Remove the window regulator handle.
    1. Remove the spacer.
  1. Remove the parts in the order indicated in the following table.
    Item Part Number Description 1 224A60 Cover plate 2 N602704-S301 Screws (2 req'd) 3 14B132A (RH) / 14B133B (LH) Window control switch 4 14630 (RH) / 14631 (LH) Window control switch electrical connectors 5 W505424-S301 Bolt 6 W701930-S424 Bolts (2 req'd) 7 19A034 Water shield 8 W709132-S300 (High series trim) / W709133-S300 (Low series trim) Speaker standoff (2 req'd) 9 219A65 (LH)/ 219A64 (RH) Front door handle
    Removal Note 10 23942 (RH) / 23943 (LH) Front door trim panel
    Removal Note
  1. To install, reverse the removal procedure.
Item 9: Front Door Handle Removal Note
  1. Guide the door handle through the opening in the trim panel.
Item 10: Front Door Trim Panel Removal Note
ani_caut.gif CAUTION: Do not pull directly outward on the front door trim panel, as damage may occur.
  1. Lift upward and remove the front door trim panel.
2010&c18=modelyear&c20=n717901&c35=wsm%2cfront%20door%20trim%20panel%2cs42%2c501-01%2cremoval%20and%20installation&pid=wsm%2ctitle%20page%202004%20f-150%2cs42&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=27&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=491&ct=lan&hp=n&[aqe]
Apr 03, 2010 | 2004 Ford F150
2003 Lincoln Town Car - Power window switch removal/installation
SECTION 501-05: Interior Trim and Ornamentation 2003 Town Car Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/28/2002 Front Door Trim Panel adobe.gif Printable View (206 KB) Removal and Installation
NOTE: LH side shown, RH side similar.
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01.
  1. Remove the window switch plate.
  1. Disconnect the electrical connectors.
  1. ani_caut.gif CAUTION: Use care not to damage the trim panel covers.
    Open the screw covers.
  1. Remove the screws and the assist handle.
  1. Remove screws and the front door trim.
2010&c18=modelyear&c20=n306887&c35=wsm%2cfront%20door%20trim%20panel%2cs3g%2c501-05%2cremoval%20and%20installation&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=582&ct=modem&hp=n&[aqe]
Apr 02, 2010 | 2003 Lincoln Town Car
Need to remove drivers door panel
please rate if this helps. Section 01-05: Trim, Interior 1995 Thunderbird, Cougar Workshop Manual REMOVAL AND INSTALLATION The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step. Trim Panels, Door Removal and Installation
  1. ssd~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
    Disconnect battery ground cable (14301) .
  1. Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item Part Number Description 1 23713 Front Door Trim Panel Finish Panel 2 17B676 Outside Rear View Mirror Control 3 14028 Door Lock Switch 4 55928-S55 Screw (5 Req'd) 5 14529 Window Regulator Control Switch 6 23942 Front Door Trim Panel
  1. Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
  1. Remove front door trim panel retaining screw through front door trim panel finish panel opening.
    Trim Panels, Door
    Item Part Number Description 1 20124 Front Door 2 23942 Front Door Trim Panel 3 383356-S100 Nut (2 Req'd Each Side) 4 56903-S58 Screw (2 Req'd Each Side)
  1. Remove interior lamp lens cover.
  1. Remove screw through interior lamp opening.
  1. Slide front door trim panel upward to disengage hooks.
  1. Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
  1. Disconnect window regulator jumper wire (14A630) .
  1. Remove front door trim panel.
  1. To install, reverse Removal procedure.
May 07, 2009 | 1994 Mercury Cougar
Car Audio & Video Logo
1,309 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
