Rjtech mpeg-4 dvd player RJ-810DVX problem please help!
Hi my dvd player says load then it switched to r00t well I think that wahat it says I cant get it to play does anyone no what the problem might be? Its a RJ-810DVX I just bought it today. please help....thanks
  • Anonymous Oct 26, 2008
    need codes to program my universal remote
  • judy9811 Mar 09, 2009
    I have the RJ Tech RJ-810DVX DVD Player. I am having problem loading it. I tried putting in new CD, it will play and then it stops. I tried cleaning it as well. I purchased this only a month a go. And I have no receipt for it. Can anyone help me fix the problem?
  • 231 Answers
SOURCE: incorrect region code DVD player
if you use a PAL broadcast system where you live ..Use the menu on dvd to set it to PAL system..If you use NTSC change it to NTSC .
Posted on Dec 05, 2007
SOURCE: Hi I need to unlock my Sanyo DVD player HV-DX350A
HI this works as i have unlocked my own Sanyo HV-DX350A player with it Hope it works for you
Unlock region code for Sanyo HV-DX350A DVD/Video player.
1. Turn on unit
2. Select DVD
3. Open tray
4. Press 0520 then in sequence press arrow up, down, left and right.
5. The region management screen is displayed on your monitor ( Code is displayed on the unit LCD display).
6. Note - Your current EEPROM region code setting is displayed on the screen.
7. Enter desired Region Code ( 0 for multi region).
8. Press PAUSE to exit.
9. Turn power off and turn on again.
If you repeat steps 1 to 4, you can view your new setting.
Posted on Mar 10, 2008
SOURCE: playing recordable dvd
I play recorded DVD-R and DVD+R on mine all the time. It only plays true DVD Video formats, so if your trying to play a windows media file anything other than a true DVD Video, it won't happen on this player. It supports DL also in the correct format.
Posted on Sep 02, 2008
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Posted on Sep 03, 2008
  • 17 Answers
SOURCE: ritech rj-810dvx dvd player door will not open
Try unplugging it, then plugging it back in. FIRST press the eject button, this will turn it on automatically. If this does not work it's stuck.
Posted on Sep 08, 2009
I have the RJTECH 4200 Karaoke Machine. Worked fine for over a year and recentlt loaded a CD and the power shut off. Tried everything, can't get it to turn on. Need help on getting repaired. p.
A repair if total dead is possible. Follow the money or the voltage in this case from cord to switch and from there to power supply--should be AC or wall voltage up to the power supply and then get rectified (changed) from AC to DC.
If no AC voltage past the switch--test it with a ohm meter--off no reading, on a reading etc.
May 27, 2012 | RJ Tech RJ-4200
Tip
How to Rip DVD to MPEG/MPEG 2/MPEG 4 ...
Quoted from: http://www.daniusoft.com/convertdvd/dvd-to-mpeg-converter.html
Do you have some home Movie & DVD Discs that you want to:
-Rip DVD to MPEG files so you can edit DVD with Windows Movie Maker?
-Convert DVDs to MPEG 2 lossless that have no copy protection on them?
-Encode DVD to MPEG 4 to watch movie on your mp4 players like iPod, iPhone, PSP, etc?
Well, you're in the right place, this tutorial will tell a quick way to convert DVD to MPEG/MPEG 2/MPEG 4 in high quality.
What We need is a third party DVD to MPEG Conversion software - Daniusoft DVD Ripper, it's not only a smart DVD to MPEG tool but also a powerful DVD RIpper softwarethat can rip DVD to up to 150+ Video audio files with amazing editingFeatures, now let’s go ahead to the steps to rip DVD to MPEG files,it’s really simple:
Step 1. Load Your DVD Movie to Daniusoft Ripper
Click 'Load DVD' button to add the DVD file. Or click 'Load File' toadd DVD/IFO from your hard disk. (Ensure that you have sufficient spaceon hard drive to store the DVD).
Step 2. Choose output format
Click "Profile" to choose MPEG-1/MPEG-2/MPEG 4 as the output formataccording to your needs. Plus, you are allowed to customize outputfiles frame rate, bit rate, resolution, encoder, etc in the settingpanel.
Step 3. Start Conversion
Click "Start" to rip DVD to MPEG files. All the tasks of conversionwill be finished at fast speed and high output quality.
When you done encoding DVD to MPEG/MPEG 2/MPEG4, you can play MPEGvideos on your computers, edit MPEG files in Windows Movie Maker, ortransfer MPEG 4 files to your portable media players like iPod, iPhone,Cell Phone, etc without limitation.
Related Glossaries:
MPEG-1 (Video CDs)
Although MPEG-1 supports higher resolutions, it is typically coded at352x240 x 30fps (NTSC) or 352x288 x 25fps (PAL/SECAM). Full 704x480 and704x576 frames (BT.601) were scaled down for encoding and scaled up forplayback.
MPEG-2 (DVD, Digital TV)
MPEG-2 provides broadcast quality video with resolutions up to1920x1080. It supports a variety of audio/video formats, includinglegacy TV, HDTV and five channel surround sound.
MPEG-4 (All Inclusive and Interactive)
MPEG-4 is an extremely comprehensive system for multimediarepresentation and distribution. Based on a variation of Apple'sQuickTime file format, MPEG-4 offers a variety of compression options,including low-bandwidth formats for transmitting to wireless devices aswell as high-bandwidth for studio processing.
Sounds Good? Free Download Daniusoft DVD Ripper to have a try!
on Apr 28, 2010 | Computers & Internet
Hello load mpeg driver vio not found
Hi
First i have to confirm you MPEG in file format of video clip or movie file, you have to install mpeg player, if try to play in "windows media player" you get no luck. so that one you i suggest to you download the VLC player, this is a multiple player to play the different type of music and video format.
1) Download the VLC player
2) Easy installation in all Windows version.
God Luck
Sep 03, 2011 | Ulead DVD MovieFactory 4 for PC
I BOUGHT SONY DVD PLAYER MODEL VIDE DVP-SR650P.. WHICH TYPE OF VEDIO FORMATS CAN IT PLAY...
It can play mpeg-4 video and divx video.
If you want to know how to burn video to DVD to play on your DVD player, this burn DVD guide will help you a lot.
Aug 30, 2011 | Sony SCPH-10420 Remote Control
I have dish network and i want to put my dvd RJ Tech at my remote control but i can't to find the code for this dvd can you help me with this ? My dvd is a RJTech RJ800dvx thks
It would be our pleasure in helping you with this. We currently do not have any codes your RJ Tech DVD player; we would recommend performing a power scan. A power scan determines if there is a code that will operate your RJ Tech DVD player.
Power scan instructions:
Step 1:
Press and hold the DVD/VCR mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Sep 17, 2010 | RJ Tech RJ-800DVX DVD Player
Ritech rj-810dvx dvd player door will not open
Sep 08, 2009 | Televison & Video
Help
Visit the remote controls manufacurers web site, they should have a code for it.
May 28, 2009 | RJ Tech RJTECH RJ-800DVX DVD Player
How to down load a movie clip
The movie file has to be into SMV file. Otherwise it will not play on the player.
ello all I had the same problems. But to sove it you have to convert you movie frist to mpeg. I use Any Video Conveter Convert it to mpeg frist. http://www.any-dvd-converter.com/products/for_video_free/ Its a free program. Or Can use media coder both are free and work great. http://mediacoder.sourceforge.net/index.htm Then Open up SMV conveter tool it only converts avi,mpeg,divx, link for this one is http://www.soft29.com/freeware/smv_converter.htm Read the help file there if you mp3 play has a 1.8 screen use setting 128 x 160 on dimesions. Tested and works with RCA,Sony,GOGEAR, and about 70 brands of mp3/4 players.
Dec 09, 2008 | RCA M4204 MP3 Player
Universal remote control code for RJ-3700
I heard that no universal remotes have codes for RJ-TECH products. Also each remote has separate codes for each brand was told by another person, My remote broke as well and I found that a lot of remotes around the house had certain buttons that did different features on my dvd player. So if you have a remote which can record the infared codes for each button (Macro codes or something) that would work but I am not sure if there is a way to get the exact buttons on a universal remote to work on the dvd player. The second option is buy a universal remote from RJ-TECH if they sell them. I am just about to check for myself now, if they dont have 1 I'm buying a new DVD player cause its usesless if I cant control all the features without a remote.
Mar 19, 2008 | RJ Tech RJ-3700 DVD Player
Televison & Video Logo
295 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
