Question about Chips M863G V1.5 Motherboard
Computer powers up but no display , have tried seperate display card but still no display to monitor . Computer is not giving any warning beeps.
  • 3 more comments
  • billsk2 Feb 10, 2008
    Have found a small burn mark on motherboard so I think I can say it has had its day and I will be off to e-buyer to get a new one .Thanks to all those that posted help,will be using Fixya again.
  • tireman223 Apr 02, 2008
    i have added a nvidia pci card and a agp card nothing and the built in card not working ne ideas thanx i had another do this but i reset the bios it worked but not this one everythings running and comeing on just no monitor
  • MELVIN0940 May 04, 2008
    QUIERO DESCARGAR ESE DRIVER
  • grazyboots Mar 12, 2009
    Hi all,comp fires up no display ,no beeps,tried another driver in board,nothing,was a bit dusty so brush out but still nothing,tried monitor on another system and is ok,tried original driver in another system,seems to be stuck on start up mode but no windows,tried safe but 0,tried norm but 0,drive has no back up so i can't recover either.has both motherboard and driver had it ..
    please send answers to grazyboots @ yahoo.co.uk,
    thanks all
  • Hairy29 May 11, 2010
    hi!good pm...hope this will help...
    have you tried using other monitor?try to replace your monitor if you have one and see if it works.is the light indicator on your monitor green or orange when you power up your computer?
    Problem Solver:
  • 12 Answers
Check the cpu fan, and you kwon what, check the video card ther is some more slot available change it !
Posted on Feb 10, 2008
  • 33 Answers
This type of problem is so common nowadays. What I did is open up the casing, pulled out the RAM and by using pencil eraser, rubbed the contact pattern. Put it back and turn on your computer. Always work for me and hope it might work for you too.
Posted on Feb 09, 2008
Hi, all. If you are using a seperate video card instead of the onboard video adapter. Try going into the bios to make sure the first selection is for video is PCI, or AGP. The choices usually are,
PCI, AGP, and ONBOARD or sometimes, internal or embedded.
Try to make sure the selection is PCI. This tells the bios to look for a PCI,card first. I dont know if this will help, but at least you know the motherboard will have the correct settings in the bios. Good Luck.
Posted on Dec 08, 2009
Mu best suggestion is..............Don't buy it
Posted on Apr 26, 2008
    Problem Solver:
  • 42 Answers
Hi!good pm...hope this will help...
have you tried using other monitor?try to replace your monitor if you have one and see if it works...is the light indicator on your monitor green or orange when you power up your computer?try to check the connection of your power cable & your cpu...
  • 983 Answers
As i think you didnt connected the monitor power supply or the cable from monitor to the cpu is not connected or may be there is loose contact... just check this two you may have missed any of this 2 ...
if so connect it ...
or may be the monitor is not powered on .. there will be one button to switch on the monitor just switch on that one & try .....
No display
do you mean the moniter display dosnt work? check cable plugs at computer and moniter are tight and secure
Jul 06, 2010 | Chips M863G V1.5 Motherboard
Pc Chips M863G V1.5, install a HDD
From the manufacturer's web-site:
http://download.ecsusa.com/dlfilepcc/manual/m863/863AG-G_15D.pdf
I downloaded the manual for the V1.5 motherboard, and there was no direct, no indirect, answer to your question.
So, you'll have to "experiment".
Jan 16, 2010 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Blank monitor upon turning on PC
Well.... The motherboard could be dead... or check the power supply unit. Check the memory chips, see if the capacitors around the processor looks blown up (then motherboard is kaput) or make sure the monitor is properly connected to the motherboard monitor port... It could be numerous reasons ... See if the processor cooler fan is running and check if the processor's cooling paste is OK which would cause the processor to run TOO HOT and would prevent the PC to start-up etc etc....
Jul 20, 2009 | AMD M863G (M863G15CV22ARV000) Motherboard
I Have a chips m863g v 5.1 motherboard but can't seem to locate the pci modem drivers for it. need help locating the drivers for it
If it has a pci slot modem card then you would go to the modem card manufacturer's website to download the driver. You'll need to know the manufacturer & model # of your card to do this. Once on the website you will click the support link, lookup your card model #, & then download & install the proper drivers for the operating system you are running. Hope this helps.
Mar 30, 2009 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Motherboard CD
Hi fgetulio, PC Chips only list manual & bios file for MB M863G V5.1)
(No listing for M863G V5.1C).
You should be able to download the drivers for (M863G (V5.1A) at this link;
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=343&DetailName=Driver&DetailDesc=M863G(V5.1A)&CategoryID=1&MenuID=39&LanID=2
Create a folder & name each folder. Download the drivers listed on PC Chips web site. Uncompress each file. Than burn to CD. Each driver is separate from the other. Can not create a manufactures CD, where all drivers are installed automatically. You'll have to install the old fashioned way. one at a time.
Good luck fgetulio!
More questions?
Mike
Dec 29, 2008 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
I have a PC Chips M863G Mobo wont see floppy
Download windows for with no need floppy, and boots from your cd'rom
Dec 18, 2008 | PC Chips M863G Motherboard
Upgrading to 2 GB Memory - only one DIMM recognized?
have you booted your computer into bios and see what it tells you there
Aug 19, 2008 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Manuals Mainboard pcchips M863G v5.1C
Zirius,
there is a PC-Chips M863G V5.1A motherboard site only. No referance to V5.1C. Click this link for the manual & or drivers.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=343&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
Enjoy!
Mike
Aug 04, 2008 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Chips M863G V1.5 Motherboard Logo
1,013 people viewed this question
Top Chips Computers & Internet Experts
Alun Cox
cwradio73
Are you a Chips Computer and Internet Expert? Answer questions, earn points and help others
