Question about Nikon Coolpix 8800 Digital Camera
Photography When I use external slave flash for modelling the picture is underexposed How to set the camera function whether on manual mode or the auto mode
    Sniper:
  • 53 Answers
Set it in manual, and open up the aperture. Flash exposure is mainly affected by aperture, Also make sure your shutter speed is set at flash sync speed
Posted on Feb 09, 2008
Canon 350d slr flash problems
fiist the built in flash isn't super powerfull , try the green cornered (auto) mode inside home, be shure to make it a dark site , zoom in on a subject in the dark and the camera should pop up the flash, loading the flesh costs a bit time and power so be shure that the accu is full , if the flash doen't react check in the manual if it isn't switdhed off , bur in auto mode it should popup and flash , if you take pictures in the dark often a lens with a greater light sensivity is a usefull option , normal lenses go from 1:3.3 - 5.6 (for example) a light ensivity lense is a f2.8 , f1.8 or f1.4 in diafragma . lenses tha have the same diafraga (f2.8) over the entire range are more expensive and ussually better than a lens from f2.6 - f 4 in the same zoom range
Aug 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I think my flash is too bright?
Make sure that the exposure compensation is at zero. If that does not work, make sure that the flash is on automatic brightness. Check the manual if you do not know how to do either one of these.
Apr 11, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
My snaps are underexposed with 350D camera and 580EX TTL
Set camera:
Single shot mode not servo/C modes
Focus sensor set for center
Make sure exp. comp is not set on -(minus) side.
Make sure your subject is locked on and not moving out of the autofocus (center) sensor.
atdlee@netzero.com
Jan 02, 2008 | Canon SPEEDLITE 580EX TTL Flash
Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Sep 25, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Why do my pictures look too dark?
You may need to use the flash. Make sure the setting is not flash off. If you're using the flash, make sure your subject is within the range of 14 feet for wide angle shots or 11 feet for telephoto shots. Use Image Expert to adjust the picture's brightness and contrast. Try adjusting the camera's exposure or sensitivity settings (use the Manual user mode). If you're taking pictures in the Manual user mode, look for the EV! warning that appears on your LCD screen when you are taking pictures out of the ideal exposure range. If you have trouble setting both the aperture and shutter speed manually, try adjusting the aperture and letting the camera choose the shutter speed with Aperture Priority mode. If you're using the macro mode to take a close-up photo, be sure to provide adequate lighting for your subject. If you're taking a picture at night and you want to light up the background as well as your subject, use the camera's slow synchronized flash mode. If you need more light, attach an optional external flash to the camera's hot shoe.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
Portraits underexposed
Whenever you are taking pictures of people within six feet of them, it is a good idea to turn on the flash - whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the right arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Dark pictures
Be sure that you are capturing images in the right shooting mode. For example, if shooting a night scene your image will be underexposed and dark if the image is captured in the Program Auto mode for regular photography, or in any mode other than Night Scene. Be careful that when capturing images, nothing is obstructing the flash.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Outdoor portraits underexposed
Whenever you are taking pictures of people within six feet of you, it is a good idea to turn on the flash whether you are indoors or out. The Flash mode is easily accessed via the arrow pad on the back of the camera. Press the up arrow key, which has a lightning bolt icon, to enter the Flash Mode. Press the down key to select the lightning bolt icon and press “OK”. The flash will fire every time in this mode. Your outdoor pictures of people should improve in appearance since the flash will fill-in shadows normally apparent in outdoor shots.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Dark pictures
Dark pictures
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Nikon Coolpix 8800 Digital Camera Logo
154 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
