Printer issue I have recently hoocked back up my MFC 9200C to my computer and it does not communicate. I remember having this problem before and someone showed me how to reset the printer on the pad on the printer itself, but I don't remember. Any solutions? My printer is hooked to the computer by a USB cable. When I give a print command nothing happens.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    is this a printer issue or a UPS issue. Can you clarify please?
    Problem Solver:
  • 5 Answers
Do this if your printer is connected to your pc with a usb cable check the connection from the sytem unit then to the printer itself if finely connected then check from the control panel where you have set it as the default printer.
Posted on Feb 10, 2008
I have a Brother MFC-7860DW. Scanner does not connect to pc
I was having this problem. All I had to do was make sure I had the right IP address under the Network Setting properties for the device under Scanners and Cameras.
Mar 25, 2012 | Brother MFC7860DW AllInOne Laser Printer
HP 9200c Digital Sender gets to logo screen and stops..
Connect the scanner to an old USB HUB, and it will work. It stops when you connect to a new USB connection direct in a new PC. Done it. I worked with a 2 port USB HUB. Was posted someplase but I cant remember where. Magnar Vereide Datainstituttet.no
Jun 01, 2011 | HP 9200C Digital Sender
I have a Brother MFC-490cw and I'm trying to scan to a laptop with Windows 7. I get a message saying 'Connecting to PC' and nothing happens.
Following are some of the tips, which you must follow while you are using a printer with Windows 7 system.
Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well.
Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on.
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
Jan 28, 2011 | Brother MFC 490cw Color Inkjet...
Have recently changed modem and also WEP key. After entering the new WEP during the Seup LAN wizard, I attempt to hit ok as instructed but the printer just beeps at me. Even when I reenter the old WEP, it...
i would suggest that you need to contact your router manufacturer regarding this because you are trying to setup the printer wirelessly.once you change your modem your router should communicate w/ it and it needs to be configure by your router as well for a good communication
Apr 02, 2010 | Brother MFC-665CW All-In-One InkJet...
I have a brothers mfc 9200c and it shows me error 33. What is this
Check your owners manual or users guide. It may be available for download from Brother, check the portion of the page for the country or region that the printer was purchased in.
There is some information about error 33 in the FAQ section of the site for the MFC 5100, check if it applies to your product. It seems to have something to do with the motion of the print heads.
Good Luck!
Feb 05, 2010 | Brother Office Equipment & Supplies
Where can I purchase a print head P/n COC831207 for a Brothers MFC9200C?
That's not the right part number, but check at
www.precisionroller.com under your model number for the part and price.
Jan 28, 2010 | Brother MFC 9200C InkJet Printer
Control CENTER for brother MFC 9200 C
Please visit this link for any helpful information regarding MFC 9200C, you can put your querry directly to Brother Printer:
1. Brother Printers 9200C
2. For DCP 7020 printer
Just use the FAQ and get support from brother website. I cannot say, why the Brother website did not mention for the MFC Management Software, use with Keyboards (may be it is not user friendly or compatible for all Operating system)
For any other querry, you are welcome to get help from me, anytime, anytype.
Regards,
Ellin Scott
Oct 30, 2008 | Office Equipment & Supplies
MFC 7420 MULTI FUNCTION
i had the same experience, everytime it issue, the best way is restart your pc and printer.
then should be working fine.
Aug 13, 2008 | Brother MFC-7420 Printer
CONNECTING PROCESSOR TO PRINTER
I have the same exact issue. And I am a network administrator
May 17, 2008 | Brother MFC-3240C All-In-One InkJet...
Wont work
The issue you have posted does require little more information in order to isolate the issue to fix it. Information like have you installed the printer driver and connected the printer cable to the system in your system for the printer to communicate, are you getting any error messages when you are trying to scan or print, weather you have used the printer earlier and it was working fine till the recent past or it was just being used for sending faxes only and printing and scanning was not tried earlier, However let me provide you few steps that you cold try to fix the issue.
  1. Click on start point Control Panel and click on it.
  2. In the control panel window click on the icon labeled “System”
  3. Click on the Hardware option at the top and then click on Device manager.
  4. On the device manage page check if you have any devices under “Other Devices option with a YELLOW ! mark, if so right click on the device and left click on uninstall.
  5. Close all the windows and then insert the Driver disk for the Printer in the CD/DVD Disk Drive to install the drivers for the printer.
Note: At this point of Disconnect the printer cable if it is connected to the system tower, and do not connect the cable until the installation wizard prompts you to do so.
If you do not have the Printer driver disk handy then you can download and install the printer driver form the link below:
Brother MFC-3340CN Printer & Scanner Driver USB (Free Download)
http://www.driversdown.com/drivers/10429.shtml
Brother MFC 3240C Printer & Scanner Driver USB (Free Download)
http://printers.free-driver-download.com/Brother/25079/Brother-MFC-3240C-Printer-&-Scanner-Driver-USB-v.A-Windows-98-ME.html
  1. During the installation the wizard will prompt you to connect the printer USB cable to the system tower, so go ahead and connect it.
  2. Once the installation is finished restart the computer.
Should you require any further assistance regarding the
printer or even require assistance regarding any other
computer related issue in future please feel free to
contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 30, 2008 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
