Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Kenmore 55533400 cold air not comming over to frige side,
No ice or blockage in route
  • 833 Answers
Cleve...Without removing panels from inside the box, you will have trouble knowing if there is ice or not. Do you hear fans and feel air moving from the various vents? Many boxes do have fan shut offs so you'll have to find the door light switch to be sure. Fans rarely go out. If the fans are working, I'd consider fully defrosting by leaving the unit open and unplugged for a day or two.
If there is air movement, is the compressor coming on (you've given very little info)? Have you cleaned the condenser coils under/in back of the box?
Posted on Feb 09, 2008
Kenmore S/S-Cold air from freezer not blown to refrigerator
check for any ice blockage ad damper operations
Feb 12, 2010 | Kenmore Refrigerators
Does not get cold for freezer or main frige
IT MAY BE BLOCKED UP WITH FROST, TRY REMOVING FOOD AND UNPLUGGING FOR AT LEAST 6 HRS WITH DOORS OPEN.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Freezer is working good but the frige is 52
OR
Aug 17, 2009 | Refrigerators
Blowing cold air but not cold enough to keep frige cold
if one of the panels in the fridge has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side is fine but frige side is hot
the fridge side light bulb may be staying on,check door light switch
May 02, 2009 | Maytag MSD2656G Side by Side Refrigerator
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
