Question about 3dfx VOODOOtv 200 (VTV2003) Video Capture
AV INPUT asaptor
Hello
i bought a sport-cam(external cam) to plug on my camcorder,my problem it's thatt my camcorder has only got the output AV, and i need the Input AV to make it working.
My question: is it possible to find an adaptor AV input? if yes where can i buy it.
Many thanks
  • 82 Answers
No if yours doesnt have any inputs then there is not a way is there any inputs for another type of cable you might be able to get an adapter
Posted on Feb 09, 2008
How to project an image from an external device from a Sony Camcorder HDR-PJ240E?
Simple solution. You connected an output to an output. The Camcorder 'outputs' image from it so you need to plug it into an input on your TV. You will then see image from the camcorder on your tv.
Nov 25, 2014 | Sony HDR-PJ240E/B Full HD Handycam...
Can i hook my lap top up to this tv to get netflix? How?
Hello
This model CRT tv cannot be connected directly to lap top. Laptop has VGA output and there is no VGA input to this TV. Tv has only AV sockets to connect in. You must have a VGA to Audio Video converter to be used in between TV and Laptop. This device can be bought from electronc shops. It will have a VGA input, and audio video output. You have to connect your laptop to this device using a VGA to VGA connecter, and from this devices' output, you will get audio video output, which can be connected to TV and select the TVs' input to AV. OK.
Jun 03, 2011 | JVC AV-27F702 27" TV
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
How can I hook this cam up to my Television?
For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
Nov 04, 2009 | Canon ES75 Camcorder
I cant plug my jvc to my tv .Each time i try,nothing shows up.
I am assuming that you have an AV cable which you need to have connected to your camcorder at the AV output socket, and the other end should have RCA phono plugs (one red, one white and one yellow) which usually connect to three corresponding sockets on the front or side of most modern TV sets, these may be inside a front panel which opens. Once connected, you need to select the appropriate AV input on your TV remote, very often this will be "Front AV" or AV3 or AV4, you need to check your TV instruction manual to be sure of which input is required for your specific model of TV...hope that helps!
Oct 13, 2009 | JVC GZ-MG130U Camcorder
Poor/broken connection at AV terminal
You can easely replaced the input/output AV connection. But first use an new AV cable. I fyou need a servicemanual send an email to Rotronica in the Netherlands
Apr 19, 2009 | JVC Cybercam GR-D70 Mini DV Digital...
No analog input option on my camcorder menu!!!!!
analog input are those using RCA plug or mini headphone plug, so if you are making no connections to this ports, maybe its off. Or an option to switch between digital and analog and selecting digital input would turn off analog input.
Feb 06, 2008 | JVC Everio GZ-MG155 Camcorder
Panasonic DS27 Camcorder IE1394 firewire out problem
http://www.panasonic.co.uk/customer-Support/download-centre.asp
See bottom two files, I think you may have a problem with your firewire port on your camcorder
Dec 06, 2007 | Video Cameras
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
3dfx VOODOOtv 200 (VTV2003) Video Capture Logo
259 people viewed this question
Top 3dfx Televison & Video Experts
Marvin
Marvin
Are you a 3dfx Televison and Video Expert? Answer questions, earn points and help others
