Monitor screen display in stretched out and not proper
The screen appears in different shapes and sizes when it is switched on everytime.also control locked and unlocked is displayed the middle of the screen which doesnot go even when the menu button or exit button is pressed.kindly provide a solution for this.
  • Anonymous Feb 16, 2008
    upper part of the monitor is stretch and rest part is ok.
  • 44 Answers
Tell me the monitor model and year of make...
if the screen displayed in different sizes and shape when u on it and change mode while in on position after few minutes then this is problem in the Horizontal-vertical section of yoke coil. check out the polyester capacitor & mosfets in that area. also check the center drive inductance and the width control inductance.
the processor might be locked due to front panel keypad keys....
the solution is ----make a call to that company they will tell u the unlocking procedure. if it still prisist then change the memory IC.
at last change the processor...
Posted on Feb 08, 2008
Why is video stretched?
Removing the power erased the memory setting for screen size. Locate and go in the menu controlling size and reset.
Sep 07, 2015 | Televison & Video
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
How do i enlarge the print on the screen
there are several things you can do, change the screen resolution, or change the size of the text, to do this go to Control Panel - Appearance and Personalization - Display then click the 125% radio button and apply. in versions of windows older than windows 7, this process may be slightly different, this option may be in the ease of access centre. if you have trouble changing either of these things type your operating system and change screen resolution or change text size into google. to change the screen resolution go to control panel and in appearance and personalisation click adjust screen resolution, this will make everything look bigger, try to keep near the same aspect ratio or photos and text will look distorted or stretched.
Mar 14, 2011 | AOC Computers & Internet
Image stretched widthways
Hi
Depending upon your operating system: Right click on an open area of the background screen. The goto to settings or display settings. From here you're going to want to change the display resolution or display size to match your monitor. Experiment with the different sizes until you get the one that's right for you.
May 13, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
Change screen size
Start menu to Settings to Control panel to Display to Settings to Screen resolution.
Change the resolution to one that suits you!
Apr 28, 2010 | ViewSonic VA2323wm Monitor
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Print too small on computer screen
In the Menu bar, click View, then Text Size and select larger text.
You can also make a web page larger by pressing CTRL and + at the same time.
You can reset the monitor display in Control Panel, Appearance and Themes, Display, Settings. Adjust the screen resolution to match the shape and size of your monitor
Nov 11, 2009 | Compaq Computers & Internet
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Computers & Internet Logo
1,102 people viewed this question
David Payne
David Payne
