Question about Car Audio & Video
Nedd help with my car audio
I have the lanzer mxa282 amp and 2 15 '' power acoustik they are the pw2 series subs the subs say that they are 1300watts max how should i hook up the + and - fro the amp to the subs becouse thise subs have 2+and2-pleas help
  • 65 Answers
Here's your best bet. Crutchfield magazine has THE best site for training. The link to the page for you is http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html
You will need to know how many voice coils your sub has, how many ohms and how many channels you amp has, then click the appropriate link. Good luck and don't forget to leave "FixYa" for feedback.
Posted on Feb 08, 2008
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
How to install a power acoustik 30th anniversary version series 4 channel 1200 watt amplifier
Power to battery. Ground to something in trunk. Remote to blue lead on radio. Rca to line or sub out on radio.
Sep 14, 2017 | Power Acoustik Car Audio & Video
My 620 watt power acoustik amp is on protect mode for some reason, and it is ran to two 10" subs. i need help?
this is usually an anti theft precaution taken where if the amp is tampered or attempted to be stolen it will shut down making it useless for the thief the only way to get them unlocked is usually by the people whom installed it for you or the manufacturer
Dec 19, 2010 | Power Acoustik TS1440-2 Car Audio...
I have 2 15''s dual voice coil and i need to know how to wire them to my power acoustik bamf 4000 in a 1 ohm
most car-audio subs are rated at 4 ohms, as opposed to home audio's 6-8 ohms. If you have a pair of 4 ohm subs, wire all 4 positive terminals to the positive terminal on the amp and the sam with the negative sides. The key is to use the same length of wire on all connections.
Apr 28, 2009 | Power Acoustik BAMF4000/1D Car Amp
How do i wire two 15 inch subs to 2 ohms
Hello familia_gome,
Those MOFO-15's have dual 1ω voice coils. So the only way you can get 2 of them to present a 2ω load is to use 1 voice coil on each one with the two of them wired in series. Using both voice coils, you can get a 1/4ω load by wiring the voice coils in parallel and then wiring the subs themselves in parallel. You'll get a 1ω load with the voice coils in series and then parallel the subs. Or you'll get a 4ω load with both the voice coils and the subs in series.
Here's a link to Power Acoustik's PDF for the MOFO's. I recommend that you check out the wiring diagrams on page 3.
http://www.poweracoustik.com/SUPPORT/MANUALS/PA-MOFOWoofer.pdf
Hope this helps.
Apr 05, 2009 | Power Acoustik MOFO-15 Car Subwoofer
Will a sony 1000 watt amp model # xm-1652z run 2 dvc 800 watt rms subs?if so,whats the best way to wire them to this amp?thx
personally i wouldnt use a sony amp for powering anything but,however if your going run it what i would recommend is if the speakers are at 4 ohms then run in series per speaker then put the speakers in series as well so you will keep your 4 ohms then run the amp in mono,however just to let you know that amp will not push fubars enough to really make them thump my advice is to goto http://www.sonicelectronix.com  if you have 200 dollars you can get a nice  Hifonics TXi 1508D that will push those monsters quite well thats 1 ohm stable and will barley get warm even after hours of thumpage,also if your running subs monoblocks are the way to go hope this helps you out.
Feb 21, 2009 | Power Acoustik Power-Acoustik FUBAR-12W...
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Power acoustic ov1-30000 3000w gothic series
IT SEEMS TO ME THAT THE RADIO MAY HAVE A OUTPUT FOR THE SUBS OR REAR RCA CHECK RADIO MENU AND SEE IF THIS IS ON OR OFF
Dec 29, 2008 | Power Acoustik A3000DB Car Audio Amplifier
Compatible amp for subs
hi there. yes it should work providing you have the correct wiring it for it, if you buy the LV 416 enquire about a wiring kit to fit, most will. theyre normally around 20pounds. most amps will be compatible with most subs. i run both my 12inch 1000w off one 1200amp at half power, they kick lovely and i have no problems.
any other quiries please ask
adam
Nov 10, 2007 | Legacy 2CH 1000W AMP Car Audio Amplifier
600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Oct 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
