Question about NetGear WGR614 Wireless Router
Installation software I don't have the cd andcant seem to get my router connected to access the internet. please help
  • Anonymous Feb 08, 2008
    HI
    Sir
    I want Wireless Router Passward Chang
    Reg
    sandesh
  • danieljo Jun 01, 2008
    netgear wg56 v6
    Scholar:
  • 84 Answers
Http://kbserver.netgear.com/products/WGR614.asp
Copy and paste the above URL into your browser and download manual and software directly from thier server.
Posted on Feb 08, 2008
How to install DI 624 without the CD
The router can be installed without the CD. If you are experiencing any problems, you can reset the router to factory default settings, press the reset button at the back of the router.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Reset the router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router near the DC Power Jack). The LEDs will then blink and the routers factory settings would be restored. Please note that, after resetting the router you should be able to see the router and connect to it via LAN Cable or Wirelessly as the router automatic assigns the IP Address and gateway etc. Before proceeding to the next step please make sure that you are getting the signals as well as internet. However, the internet connection would not be secure, which can be done later.
Now, all you have to do is connect to the router and secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 06, 2011 | D-Link AirPlus Xtreme Super-G DI-624...
I bought a Westell Versalink 327W at a flea market. It did have any cord's or a CD with it. Can you help me install it please?
Basically a router dose not need any software or CD to get it install, we can install it manually, it will depend on the type of the Internet Connection that you have. the setup of the router defers in Cable and DSL connection, so please let us know which type of Connection you have and who is your ISP.
Mar 17, 2010 | Westell Wirespeed VersaLink...
C5180 all in one is not connecting via ethernet.
Before you begin: Check requirements Make sure you have the following items:
  • One of the following types of wired access points or routers: Ethernet router, switch, hub, or wireless router with Ethernet ports
  • A computer that connects to the wired access point or router
  • A Category 5 Ethernet cable to use for the HP product. (Do not use a standard telephone cable.) Figure 2: Cable comparisonc01710115.gif 1 - Ethernet cable 2 - Telephone cable (do not use) Although an Ethernet cable looks similar to standard telephone cable, each has a different plug and a different number of wires. The plug on an Ethernet cable (also called an RJ-45 connector) is wide, thick, and always has eight wires. The plug on a telephone cable is narrower and has between two and six wires.
Are you changing from USB connection to Ethernet connection?If you previously installed the software for a USB connection and now want to change to an Ethernet connection, follow these instructions to remove the USB installation before continuing.
  1. Click Start , click Printers and Faxes , and then right-click the icon for HP product.
  2. Click Delete to remove the product.
  3. Disconnect the USB cable from the product and the computer.
Step one: Connect the HP All-in-One to the network
  1. Remove any plug or protective cover from the Ethernet port on the back of the product. Figure 3: Remove plugc01710117.gif
  2. Connect the Ethernet cable to the Ethernet port on the product, and then connect the other end of the cable to an available port on the wired access point or router. Figure 4: Connect the Ethernet cablec01710118.gif
  3. Connect the power cord to the product, and then plug it into an electrical outlet.
  4. Turn the product on.
Step two: Decide whether to install with the product CD or download the software Don’t worry if you don’t have the product CD! You can download the most current software available for your product from the HP Web site at no cost. The following information might help you decide which installation method to use:
CD Download For a new product: CD installation is a quick and easy method. If you do not have a CD, you can download the software you need. For an older product: CD installation might not work if you are installing the product on a computer running a newer operating system that released AFTER the HP product released. Downloading the software provides the best results for your older product. Even though it takes more time than using the CD, downloading the latest software can help you avoid installation issues.
Downloading is the recommended method if your computer operating system released after the HP product released. About the software: The software on the CD is current to the date of the product release. The software that you can download from the HP Web site is the most current software available for your product. HP often updates software and drivers AFTER the product and CD release to the market.Step three: Install the software
Jan 16, 2010 | HP Photosmart C5180 All-In-One InkJet...
Installation of netgear dgn2000 wireless router on vista.
I understand that you are facing trouble with the installation of the router as the CD does not work. Please perform the below steps to install the router without using CD:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
4. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
5. Login to the router (username = admin password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear DGN2000-100NAS Router
Just installed new router but cannot access
Run the setup wizard on the router and have it detect the "WAN"
Choose the defaults, and you should be good to go
Nov 04, 2009 | Heating & Cooling
HOW CAN I USE MY NETGEAR ROUTER IF I HAVEN'T THE CD INSTALLER????
You don't need a CD installer to use it, but if you want the softwares to your router let me know the model of your router and I will send you the link to the drivers.
Sep 24, 2009 | NetGear DG834G Router
My belkin n mimo wirelss router won install
You really don't need the cd to install the router - if you connect the router to your PC with an ethernet RJ45 cable, this should give you access to your LAN & the internet. You can then access your router to set up your wireless connectivity.
To access your router open your web browser & in the address bar, type 192.168.2.1 - you might be asked for a username & password - for username: admin password: leave blank or if this does not work type : admin for password
Mar 24, 2009 | Belkin Computers & Internet
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Unable to get laptop to connect to the internet.
I have resolved the problem by doing a system restore. I set the computer to a previous date and this seems to have sorted out the problem. I guess that I may have had a software confliction.
Many thanks.
Nov 27, 2008 | 2wire HomePortal® 1800HW Router...
F5d7230-4 router
The driver software that you are installing is probably not for vista
Try to download an updated version for vista
Dec 02, 2007 | Belkin (F5D7230-4) Router (587009)
NetGear WGR614 Wireless Router Logo
150 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
