Vason 10.4 inch portable tv tuning problem
This neat little TV works fine from my home aerial on freeview, but when I try to tune it to terrestial TV, it only finds channels 1,4 and 5.
When I watch it auto tuning, it finds channel 3, but doesn't store it.
I have set it to PAL-I, which I believe is correct for the UK.
I have another TV which works fine on my home aerial.
Any advice would be welcome........
  • 2 more comments
  • BobC1 Feb 08, 2008
    TV is a Vason 10.4 inch portable TV/DVD player.
  • Anonymous Feb 27, 2008
    I have exactly the same problem.
    Digital scans and stores without a problem but Terrestrial channels don't all store and I can find no way of manually storing.
  • Anonymous Feb 28, 2008
    I have exactly the same problem having just bought one of these units.
    There seems to be no manual facility for storing or tuning channels, and even though the scan finds them, it doesn't store.
    I have tried tuning it on normal, boosted and attenuated aerials without success.
    DVBT/Freeview tuning is not a problem.
    It would also seem it doesn't play home recorded DVD's even if they are closed.
    This unit will probably be going back from whence it came.
  • bb55delfino Aug 28, 2008
    same sorta prob freeview finds around 28 programs but only stores 12. cant get beeb 1 or 2 it starts at itv1
  • 3 Answers
I returned my original TV/DVD to the suppliers who then sent me a new one.
I experienced exactly the same tuning problem with the new TV.
The only way I could tune it, was by using the fine tune facility to find and store the missing stations. This took a lot of time and continuous button pushing, so patience is essential.
Once found and stored, the previously missing channels are perfect.
It would appear that the DVD player doesn't like DVD- recordings from my home recorder. If they are re-coded they work.
Anything recorded on DVD+ is fine.
In my opinion this is a good unit let down by a couple of niggling faults.
Posted on Mar 23, 2008
SOURCE:
42LG7000 not tuning
is your tuner set to scan for cable channels or tv channels. there is a difference though the cable input and the tv input use the same connector
Mar 03, 2015 | LG 42LG7000 42 in. HDTV LCD TV
Panasonic User Manual
as far as I am aware, you need a standard analogue aerial to receive Freeview, not a dish. The aerial plugs into set top box, which is connected to tv by scart. Freeview is different from Freesat
Nov 08, 2013 | Lands Phones
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
How do you tune in tv channels when you only have a signal input from a satelite dish and no sky decoder. TV is a sharp lc-32l400x with built in freeview. Can we plug dish straight into TV aerial port...
You require a satelite decoder/receiver for your dish and an aerial for your TV.
The choice is yours. Plug a satelite receiver, for freesat, into the A/V input on the TV or have an aerial installed for freeview.
Jan 19, 2011 | Televison & Video
I can not set up my freeview on my samsung 52 inch LCD can u help me step by step as I hav no instructions thanks
Plug your aerial into the freeview box. Connect a scart lead from the freeview box to your TV and switch on.
The freeview box, if new, will search for channels itself and as your TV will recognise that it is plugged in, will auto switch to the freeview box.
If it is not new, select menu on the freeview box and follow the instructions for tuning.
There is nothing to tune on your TV as you are using a scart lead.
Hope that helps.
Nov 14, 2010 | Televison & Video
Have a new digital TV, can only record the 5 terrestial channels, how do I tune in to the other digital channels, i.e. BBC3, E4 etc.
It's not clear what you mean! So one of these answer might solve it. If you are talking VCR recording it must either have a freeview tuner or have a freeview box connected to it via a scart. Otherwise it will only record the five terrestial.
Digital TV -you must have a good aerial otherwise you will not pick up all the stations. If it has a hard disc drive the same will apply.
If the terrestial stations have any grain or the picture is not as clear as a bell on all, then your aerial will not be good enough. The type of aerial should be for freeview. See image below also you need to have CT100 cable (the stuff used for satellite) not the old brown co-axial cable (see below).
Jun 05, 2010 | Televison & Video
How do I retune my TV.
Ensure you have a working aerial connected to the back of your TV.
With you Tv remote press the tv button, then MENU go down to setup and then to auto tune. Once this has auto tuned. then press your DTV (freeview) on the remote then press the MENU button then go to setup and then auto tune. This will do the same as before but with your built in freeview.
Hope this helps you out
Little Dish Fitter
Sep 28, 2009 | LG 42LG50 42 in. LCD HDTV
My Sony KD28DL10U digital TV will not tune into freeview
I think this is one of the TV's that wont work as part of the Digital Switchover as it's too old. My Brother has the same TV and has had to buy a new Set top box to get Freeview.
Jun 10, 2009 | Sony Televison & Video
Televison & Video Logo
576 people viewed this question
Top Televison & Video Experts
Ekse
