Question about Sony PlayStation Portable (PSP) Console
Psp how to put on a downloaded theme into the psp
  • 4 more comments
  • linu_x Feb 08, 2008
    it is 3.60
  • Anonymous May 24, 2008
    Hi i have manually created "THEME" folder in PSP/THEME folder and copy a theme, with a extension .ptf into THEME folder
    but there's still no selection for me to choose which theme i want.
    My software version is:3.40 OE-A
    Pls help. Thank you.
  • conejo2 Nov 20, 2008
    no se
  • Ida Nyland
    Ida Nyland May 11, 2010
    What version is your PSP?
My web browser is not staring even te internet is connected?
Posted on Nov 20, 2008
    Problem Solver:
  • 16 Answers
Place the file in "psp/theme"
Go to themes and choose the theme to use..
Posted on Feb 08, 2008
Themes that i downloaded,where should i put it??because i putted it in the themes but it is not there when i want to use it as my theme
You have to first download the theme off your computer, you cant get it from your psp's web browser. Then after you connect the psp to your pc, you have to make a new folder in the root of your psp memory card named "THEME". All you have to copy into the THEME folder is the .ptf file. The .ptf file is the theme. Then after you should be able to see it in your psp. Hope I helped!
Aug 06, 2011 | Sony PlayStation Portable (PSP) Console
Psp themes
psp themes can be downloaded from any where. try www.ezpspthemes.com www.psp-themes.net www.pspthemecentral.com
after downloading it, just put the theme onto a folder in your psp labelled "THEMES"
Nov 02, 2010 | Sony PlayStation Portable (PSP) Slim...
I have problems with my psp theme
Make sure it is in themes folder and also you need to format the memory stick to put stuff on it
Mar 27, 2010 | Sony PlayStation Portable (PSP) Console
How to put themes on my psp
if you really want to put themes on the psp..if you connect your psp on the pc youll see there all the folders of your psp..look for the theme folder and put the selected theme on it..then chose the downloaded theme from the theme setting menu..also u can use pic as your background..
Mar 10, 2010 | Sony PSP-3000 Silver Console
Will not do any kind of updates or themes
download theme files for example and then put the in the PSP/THEMES folder
make sure you are put the themes inside the memory card! remember PSP/THEME/ [theme file/s here}
Dec 27, 2009 | Sony PlayStation Portable (PSP) Console
I am not able to download themes in my psp
You don't have to create a themes folder on the on the memory stick duo, it is already created on the memory stick duo, all you have to do is to just connect your psp to your computer and activate the USB connection under settings on your psp, if you have firmware update 5.00 or higher, there is a feature called USB auto connect under system setiings which automatically switches to USB mode when you plug in a USB cable to your psp and your computer.
STEPS TO DOWNLOAD THEMES TO YOUR PSP.
1. connect your PSP to your computer, go to MY COMPUTER on your desktop and click on the drive that represents your PSP.
2. double click your PSP drive and navigate to PSP folder and select THEME under the folder.
3. Now copy and paste this link to your browser to download many themes for your PSP: http://dl.qj.net/index.php?&catid=538&name=PSP-Themes-PSP-&p10=5
4. select the file you want, click on download, depending on your browser, click SAVE when you are prompted to RUN or SAVE the downloaded file. Please select the PSP drive under MY COMPUTER and select PSP, navigate to the THEME folder and save the file to this folder.
Now disconnect the PSP from your computer and select THEME SETTINGS on your PSP, select THEME, navigate to the available themes and you will see a preview of the theme, select apply to use the new theme.
PLEASE RATE ME.
Dec 14, 2008 | Sony PlayStation Portable (PSP) Console
The theme problem
1.Download CXMB for 3.90 off this website
2.Connect your PSP to the computer
3.From the file you just downloaded go to CXMB_for_3.90>CXMB_FULL and take sepluginscxmb and ._seplugins and put them in the root of your Memory Stick
4.Go to recovery menu and enable the cxmb.prx plugin
USING CXMB
1.Download a CTF file off from the internet somewhere
3.Drag the CTF file you download and put it in X:/PSP/THEME
4.Go to SETTINGS>THEME SETTINGS>THEME then select a theme that you have put on your PSP  and press X then press X on apply
5.Your PSP will restart and the theme you chose will be on your PSP
Oct 26, 2008 | Sony PlayStation Portable (PSP) Console
I need help
To use the .CTF Themes you need to download the plugin called cxmb.prx
1. Download the plugin (cxmb.prx)
2. Extract the file and place into root of your MS0:/
3. Put the theme file (any name you like :)) under MS0:/PSP/THEME/
4. Enable cxmb.prx in Recovery (under VSH)
5. Go to Settings -> Theme Settings -> Theme to select your CTF themes
6. System will reboot to take effect
To Use the .PTF Themes download it first then put it inside ms:/PSP/THEME. if the folder is not there please create it. To apply the theme on your PSP, go to “Settings” => “Theme Settings” => “Theme”.
Oct 24, 2008 | Sony PlayStation Portable (PSP) Console
How to download psp themes??
There are actually a lot of themes running around the internet now...just type in your search bar PSP themes. How, for the location of the themes, just put it in your themes folder on the memory card of your PSP>>ms0:\PSP\THEME (ms0: meaning the root directory of your memory card)
Aug 03, 2008 | Sony PlayStation Portable (PSP) Console
Help
once connected by usb you have to go onto the psp root and should find a folder called THEME place the file into there but older firmware versions do not support themes after placed the themes in the folder disconnect the psp and on the settings menu of the psp go on display - themes and select the theme there
rabbit07
Feb 23, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
51 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
