Question about Sanyo PLC XU33 Multimedia Projector
Sanyo Pro xtra projector - warning light
Hi we have a new ( 2 week old) projector. When we turn it on the green light appears and it seems to be turning on. After about 15 seconds the warning light appears and it will not turn on. The cycle keeps repeating itself.
We were left no user manual.
Than - you
Craig
Northside School
Botswan
  • sedda Mar 04, 2009
    Our projector appears to be turning on and then the red light flashes and the warning light comes on. I have cleaned the filters.
  • elmuzzerino Apr 28, 2009
    In my school our projector goes for days or weeks, then the warning light comes on and it will not go away until we unplug the projector and leave it for a few mins. annoying!
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Posted on Mar 07, 2008
Easy Fix, there are two air filters that need to be cleaned.
Posted on May 14, 2008
  • Tharaka Sangeeth
    Tharaka Sangeeth May 22, 2014
    I also have the same froblem and i have clean two filters. But it dosn't work. How i fix this issue ?
SOURCE:
How do i reset sanyo pro xtrax multiverse projector "replace lamp" error message
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Sanyo PLC-XE20 (Chassis XE2000)...
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
I turn on my Viewsonic PJD6251 but the lamp does not come on, and after a few seconds I get 2 red lights TEMP and LAMP. It is new, only 2 weeks I barely used. Good care.
sounds like a bad bulb
projectors get a resistance reading from the bulb and if it doesnt get right value it will give you the double red lights
only other thing it could be is if the fans in projector are not turning on
call viewsonic and tell them issue and make them resolve issue
or
if unit is only 2 weeks old bring it back to store and get replacement or call viewsonic and get them to send you replacement unit - it is too new to mess with it yourself and take chance on voiding warranty
Mar 24, 2011 | ViewSonic PJD6251 Projector
Projector frequently cutting out.
reset the lamp counter (menu-settings-lamp age-lamp counter reset-yes).
Oct 22, 2009 | Sanyo Office Equipment & Supplies
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Picture dull colours incorrect on sanyo pro xtra x projector
reset to factory default settings (from the menu). after that if it's not where you want them, you can go into the menu and set them to where you like them.
Aug 04, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC-XU33 image displayed for 10 seconds then turns off
Owner decided to upgrade to a newer projector. Lamp was too expensive.
May 07, 2009 | Sanyo PLC XU33 Multimedia Projector
Sanyo PLC XU33 Multimedia Projector Logo
11,253 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
