Question about ASUS P5LD2-VM Motherboard
P5LD2 DOES NOT PWR ON AFTER INSTALLING CONROE 6700. GREEN STAND BY LED LIGHT IS ON...BUT DOES NOT POWER ON FURTHER THAN THAT. IT WORKED FINE WITH MY P4 HT. WHAT GIVES
  • ASUS Master
  • 13,433 Answers
Check your motherboard version. Note:
Only PCB R2.0(or higher) support Intel® Core™2 processor
You should find the information between the pci slots Or close to the asus heatsink next to the cpu.
Its quite small text, eg 1.01 1.0 2.0 etc.
If the number is difrent from R2.0 or 2.0 then your motherboard does not support the cpu.
If it is so then you have to change to a difrent motherboard.
Posted on Feb 11, 2008
Hitachi 65SWX20B no picture/sound, 4 out of 5 green LEDs on, red LEDs on, green B+ LED is off. Pwr Relay clicks on, TV only turns on/off. IP02 location/How to check for 14-20V on terminal 4 of IP02?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 20, 2016 | Hitachi Televison & Video
Dell desktop test
GREEN = POWER
BLUE = STAND BY
YELLOW = MEMORY POWER
Jun 14, 2013 | Dell OptiPlex Computers & Internet
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
I have a reebok crosswalk rt 5.0 treadmill. I can calibrate the incline and it goes up and down. however when you press the button to raise the incline the incline number will change but the machine does...
Step 1:
see this details and proceed according. God bless you
LED.
Step 2:
This the board LED, who control the DC to +12vdc) then the +12V LED lights.
LED.
operating properly.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP for elevation Motor. You must clean contact of the Relay with Special Spray(Radio Schack).
With this you must fix it.
Jan 07, 2013 | Reebok Exercise & Fitness
My GX520 pwr light is green, on the board is an amber Led, the somputer boots up, it goes the full process, until the arrow appears on the monitor. no Iconn are displayed on the desktop
If your computer gets to that stage, then I would guess you have an OS ( Operating System ) problem. Try booting from your XP installation CD. If that works then you may have to re-install Windows.
Jun 23, 2012 | Dell OptiPlex GX520 PC Desktop
Dc 5000 sff. wont power up. green light on motherbd flashes. if power on button is pushed, the front green led blinks too. I have replaced the pwr supply w/no change.
make sure both the 4 pin and 20 pin connectors are firmly installed. if the mobo light flashes how many times does it flash, do you hear any beeps?
May 10, 2012 | HP Compaq dc5000 PC Desktop
My proform incline won't recline
Dear Sir:
I will try to help you.
Please see the video with patience and carefully. you nee basic tools+Dvom
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
LED.
With this you will fix it.
If you need further assistance, please reach me, sincerely.God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 26, 2011 | Proform XP Weight Loss 620 Treadmill
The incline won't recline
I will help you.please watch the videos, and use basic tools , patience , and carefully.
LED.
If you need further assistance, please reache, sincerely. God bless you.
E.CUADRA
Pc restart problem
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
Oct 03, 2007 | ASUS P5LD2-VM Motherboard
Motherboard pin config
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
Aug 28, 2007 | Systemax Ascent PC Desktop
ASUS P5LD2-VM Motherboard Logo
126 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
