Question about Quantum ATL SuperLoader Ultrium Tape Drive
ATL Superloader with LTO2 drive
The Superloader will not initialize and says drive error 3D. I have been able to narrow it down to what I think is happening based on the Xtalk tool. The drive is LTO2 and has the latest firmware and windows 2003 sees it just fine. the loader is also seen by windows 2003 but when the drive is in the autoloader the autoloader sees the drive as ultrium 1 100/200 GB when it should be 200/400 which is what windows sees it as. How do I get the firmware on the loader updated? I have downloaded the correct version I need but every time I try in upgrade the Superloader firmware using the web I get error message saying firmware upgrade failed, superloader cannot be taken offline. I cannot use the front panel to upgrade because the initialization fails. Is there a seperate utility I can use to get the superloader firmware upgraded?
The LTO family drives all support a tape-related diagnostic spec called TapeAlert, and if you use a software product that decodes it and can dump out all of the settings related to firmware, error logs, etc ... then I have no doubt it will provide root cause. Check out http://www.santools.com/smart/unix/manual (the code is also ported to windows. There are links for TapeAlert reporting) Or go to http://www.tapealert.org for info on the spec.
Posted on Jan 17, 2009
I am getting a DRV PREV REMOVAL TYPE (46) message on display, every time I try and Inventory a tape or run Lable Media.
I have two of these Quantum SuperLoader 3 (with LTO3 drives) and one does keep giving me the same hassle. I haven't figured out how to fix this, but I've gotten past the error: disconnect the autoloader from the host computer (i.e. or stop rsm, mtx, or whatever controlling sofware you use), reboot the autoloader, get the tape out of the drive (e.g. move command from the autoloader's console or web interface), insert a cleaning tape (a few times), reconnect everything (i.e. start back up your controlling service).
Nov 29, 2010 | Quantum SuperLoader 3 LTO-3 Tape Drive
Elem Table Bad (2B) error
The element error usually points to the drive, the best thing is to do is run the full diagnostics for the drive, and see what other hardware codes you receive, if it still points to 2b, then it is either the drive or the solenoid of the magazine failing. If you have a two magazine setup, just reverse the other magazine and test it that way.
Apr 16, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Nov 13, 2008 | Quantum SuperLoader 3 LTO 2 Tape Drive
USE OF DELL PV124T LTO3 TAPE DRIVE USING AND LTO2 TAPE USING WINDOWS BACKUP FEATURE IFY usua_ie@yahoo.com
I have DEll PVT110t LTO2 backup drive & my backup tape got stuck into it.please help me for the successful ejection of tape.
Aug 27, 2008 | Dell PV124T LTO3 16 SLOT COMES WITH 1 MAG...
Quantum Superloader remove jammed tape
You have to disassemble the unit and remove the tape. Chances are it's stuck in the carousel (the round thing at the front that spins tapes and plugs them into the drive).
May 06, 2008 | Quantum ATL SuperLoader Ultrium Tape Drive
If you cannot physically load a tape into the drive it is a hardware problem and the drive requires service. It is not a software problem.
Of course, the library could already have the maximum tapes it can hold. If this is the case then eject a tape from the library to make room for the tape you want to add.
I hope this helps.
Apr 17, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
Loading Media
Same problem with Backup Exec 10d and Superloader 3 LTO-3.
This is not my first problem with this Superloader. I think it is garbage and will likely be in the garbage very soon. Very expensive garbage unfortunately.
Mar 05, 2008 | Quantum SuperLoader 3 LTO-3 Tape Drive
Error on ATL M2500
most likely this is a drive issue or picker problem. did u try to power cycle the library?
Nov 19, 2007 | Quantum ATL M2500 Tape Drive
Quantum ATL SuperLoader Ultrium Tape Drive Logo
790 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
