Question about Nokia 6680 Cellular Phone
Off line mode
Offline mode when the sim card is insted
  • 1 more comment
  • Anonymous Jun 15, 2008
    my nokia n73 is always on offline mode
  • Anonymous Jan 08, 2009
    mine is stuck in offline mode and it isnt that.. :-/
  • Anonymous Feb 21, 2009
    my phone is offfline what i must do???????????
    Problem Solver:
  • 8 Answers
It may be the problem with sim card once u try it in any other handset if the same problem exists its the sim card problem only take a duplicate of it. U try once keeping other sim card in ur 6680 handset if other sim is working, u can contack ur nearest nokia care.
Posted on Feb 08, 2008
My phone is in offline mode,when i insert a sim card it ask whether i want to continue in offline mode but when i choose no, it tells me to insert sim
when you insert your sim card and press ok when it ask you whether you would like to continue in offline mode . once your phone starts go to the settings option and click the master reset or restore factory setting. once restored swtich off your phine without removing the sim card and then switch it on after 5 mins . it should solve your problem
Oct 19, 2013 | Cell Phones
Offline mode on nokia e73
Most of this problem comes due to failure of Connection between the Sim card and the Sim card slot.Since, there is no separate Sim card IC the only thing you need to check is to clean the Sim card connector or sometimes the connector might bend.Moreover, you can at least insert other Sim card and try.Otherwise, contact nearest mobile repairing shop.Good luck.Thanks for visiting fixya
Aug 08, 2012 | Nokia E73 Mode Cell Phone
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
My n70 is going offline offline mode i m trying to change profile in general mode but it say insert sim card what do i do...
someone or you might have coded that phone with a line different from the current line so you must deactivate that code by inserting the formal line.or if you dont know the code you have to flash the phone.
Mar 14, 2011 | Nokia N70 Cellular Phone
PHONE IN OFFLINE MODE . hOW DO YOU CHANGE IT TO on line mode
Ok let me give you solution about this problem....
Offline mode is the mode in cell phones which barred your every calls sms and even your internet connection simply you can say that...
It stops all of your connection......and you can use only those things which do not need the connection or network.
So to deactivate this offline mode their is two way
1. You can restart your phone after inserting sim card and if the sim card is in good condition and readable then the cell phone will ask you wheather to continue in offline mode?
Just press no that is upper right button of your cell phone and it will be deactivated.
2. Just press on/off button gently and it will show you profile i.e. to select mode
General, silent, meeting etc. you can select any of them except offline mode.and again it will be in normal mode.i hope that it will help you,
By: Neuron
http://www.digixtream.blogspot.in
Jun 15, 2010 | Nokia E51 Cellular Phone
My phone nokia 6680 has been in the offline mode.i want remove it
when you insert sim in your phone after using it offline,it should ask you if you want to continue using your phone in offline mode...select NO..Otherwise your phone cannot detect the sim card..clean sim terminals..if problem persists check and reheat sim filter IC..the crystal one, near the sim terminals itself..if all fails then UPP (CPU) or software problem..
Jul 16, 2009 | Nokia 6680 Cellular Phone
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
Nokia e65 stuck in offline mode.
step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Nov 05, 2008 | Nokia e65 Cellular Phone
Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Sep 15, 2008 | Nokia N70 Cellular Phone
Offline mode
take the sim card and put it bck again.restart it...there it will say "CONTINUE IN OFFLINE MODE?"....select no there...choose another profile and press ok...offline mode will b disabled....
Oct 23, 2007 | Nokia N73 Cellular Phone
Nokia 6680 Cellular Phone Logo
104 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
