Question about NEC MultiSync LCD1530V 15.1" Flat Panel LCD Monitor
Monitor turns on, acts like everything is fine and then - poof - no signal input....
I turn my computer on and the monitor turns on and evrything seems to be running smoothly - then the monitor blinks, then it goes dark and I get the message - No Signal Input. What can I do to fix this?!?!?!
  • Anonymous Sep 05, 2008
  • Anonymous Oct 01, 2008
    The monitor blinks on and off the goes to the now signal screen
  • 44 Answers
Check the drive section also check the triger transistor, that provide power to the other section by the processing unit. check voltage & ampers before and after, check the electrolytic filters in that section. problem must be there. also check the SMD, if anyone from them is over heating.....
Posted on Feb 08, 2008
When I turn on computer, monitor says "signal not received"'
If you monitor has multiple inputs try to change the source of the signal. Maybe a button for input source.
Oct 05, 2015 | Computers & Internet
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
Searching for signal
DVI and HDMI are the exact same signal, except that DVI doesn't include the provision for audio. Essentially the problem you're having is that you have the monitor set to auto input rather than HDMI input or DVI input. Setting the monitor to not look for any input you plug in and defining the input should cause the hunting wait to be eliminated.
Nov 23, 2013 | ASUS VK222H Monitor
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
When I turn my computer on, my monitor displays a message of 'vga signal, no vga input signal' and 'dvi signal, no dvi input signal' and 'monitor going to sleep'. My cables are...
The symptoms you described is common in fault mobo or VGA card.But VGA doesn,t turn bad so easy.I suggest to change your mobo first.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 15, 2011 | HP dx2300 Monitor Personal computer Intel...
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
No signal shows on monitor
When a computer beeps on start up there is a crucial input output piece of hardware no working. If you have any experience with computers check to make sure everything is conected right. I inclued a link for support for your computer. Larry
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3390&LINKTEXT=Support%20Solutions
Mar 06, 2009 | Computers & Internet
Computer monitor screen is blue
Can you access the bios set up.
If the bios setup is running evrything is ok except the hard disk.
To find out if there is any problem with monitor just put off the monitor and disconnect it from the cpu. Then turn it back on. If the no signal message is coming, then monitor is ok.
Your hard disk is the main suspect
If the same blue screen comes then monitor need repairs.
You may also try with another monitor on your computer to see the results. If the sane happens it is the hard disk
Dec 18, 2008 | Acer 22" X223w LCD Monitor
When i turn my monitor on it is saying that no signal or cable is not connected but ihave evrything connected
The monitor will display that message until the computer starts and outputs a valid signal to the monitor.
If the computer is on and you still get that message, then you may have a bad video card/video circuit or a bad cable between the computer and monitor.
Oct 25, 2008 | Computers & Internet
NEC MultiSync LCD1530V 15.1" Flat Panel LCD Monitor Logo
247 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
