Question about LG Prada KE850 Cellular Phone
LG Prada Can anyone tell me if the LG Prada has a water sensor in it? Can steam cause water/liquid damage?
    President:
  • 1,944 Answers
It doesn't have a water sensor.
Steam can cause it damage if it somehow gets inside the phone.
Posted on Feb 08, 2008
Temp gauge and blazer jumps around when driving
Vehicle temperature gauges (temp gauge) read the temperature of the liquid in cooling system. From what I understand, the temp gauge jumping around has since gone away after you placed water into the radiator. It is very possible that water converted into steam was trapped in the cooling system and reached the temp sensor in your engine. The vehicle moving caused this steam to shift around reflecting rapid changes in temperature on the sensor, causing the needle to jump around on your console.
Hope this helps.
Nov 06, 2013 | 2001 Chevrolet Blazer
Tip
LG KE850 Prada Unlock Code
Does your LG KE850 Prada work only with your current service provider or, when you insert a SIM card from another network, do you see any of the following messages?
  • Enter Subsidy Code
  • Enter Subsidy Password
  • Enter SIM Unlock Code (Simlock)
  • Contact Service Provider
  • Insert Correct SIM Card
  • Wrong SIM Card
  • Incorrect SIM Card
  • Phone Restricted
  • Can't Undo Restriction
  • Locked Return For Service
  • Enter Unlock Code
  • Enter Special Code
If so, your LG KE850 Prada is LOCKED and we can help you remove this lock on your LG KE850 Prada in a few simple steps, allowing you to use your phone on any GSM wireless network anywhere in the world.
You will not have to mail in your LG KE850 Prada. No Hardware or Software required. No technical knowledge required at all. Simply provide us your LG KE850 Prada’s IMEI number and we do all the rest.
Three Simple Steps
  1. Simply provide us your LG KE850 Prada’s IMEI (which can be found by typing *#06# into your phone), during check out.
  2. After order placement, the Unlock CODES together with easy to follow instructions guides will be sent to your email address within the time frame given.
  3. Follow the unlocking instructions provided by
    Reasons to remote unlock your cell phone
    • Save a fortune abroad, by using cheap local SIM Cards rather than expensive roaming tariffs.
    • As usually subsidize the cost of the phone, by unlocking it you are increasing the resale value of your LG KE850 Prada by up to 300%.
    • Use your work and personal SIM Card in your unlocked LG KE850 Prada - no need to carry two phones again.
    • Get the best value tariffs by swapping SIM Cards to take advantage of the latest offers.
    • You never send your phone to anybody.
    • Fast and easy. You receive the instructions within hours; unlocking itself takes 1-3 minutes.
    • No opening your LG KE850 Prada and risk of damage to your device.
    • Very easy, no technical experience necessary.
    • No complicated software or hardware just enters Unlock CODE, and your LG KE850 Prada is PERMANENTLY unlocked.
    • Is safe and does not void cell phone's warranty.
    • Unlocking is a one-time event. It works for the life of your LG KE850 Prada.
    Warranty
    All our Unlock CODES are 100% genuine and guaranteed, if for any reason your unlock codes are not found in our database then we will issue a full refund.
Instructions Unlocking Instructions for LG KE850 Prada
How to insert the Unlock CODE into your LG KE850 Prada
  1. Insert a not accepted SIM Card and turn ON your LG KE850 Prada.
  2. Your LG KE850 Prada will display "phone restricted".
  3. Select Cancel
  4. Your LG KE850 Prada will display "phone restriction code".
  5. Enter the Unlock CODE you received from UnlockallCellular.com
  6. Select OK
  7. Your LG KE850 Prada is now unlocked!
on Apr 07, 2010 | Cell Phones
LG KF900 Prada wont send send sms or mms texts?
FOR SMS SENDING CHECK TEXT MESSAGE CENTRE NUMBER IN MESSAGE SETTING OPTION
FOR MMS CHECK YOUR GPRS SETTING WHETHER IT IS ENABLED IN MMS SENDING OPTION
Jun 08, 2010 | LG Prada KF900 Cell Phone
My daughters LG KS360phone has stopped working - the dealer (optus) say they won't accept it for warranty repairs unless I pay them $50 in case its water damaged - does anyone know how to check for water...
The most basic way to check for water damage is to open the back cover and take the battery out. Either on the battery itself or on the phone under the battery there should be a white square or circle. This is called the LDI (liquid damage indicator), if this is still white then there is no water damage. But if this is red or pink there is water damage.
Hope this helps,
Joe
Feb 19, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
CHANGING HOUSING FOR LG PRADA KE850
Hi Purnimakant,
It's very easy to do and I have done it myself.
If you check out:
http://www.formymobile.co.uk/Dismantle/ke850disassembly.htm
There are step by step pictures there.
You can find a new case on eBay. I changed from black to silver :)
Hope this helps.
Sep 10, 2009 | LG Prada KE850 Cellular Phone
"Black/White" display theme
one possible solution would be to flash the old black prada firmware onto the silver phone; as far as i know the hardware of the phones are identical?
however, you would lose the white theme, qwerty keyboard etc.
Jan 16, 2009 | LG Prada KE850 Cellular Phone
Lg prada ke850
As long as you enter the same code on both devices it pairs fine. I use 0000 on my mobile and the same on my laptop. There is no specific code.
Now, can you tell me where to get software for mine, please?
Jun 21, 2008 | LG Prada KE850 Cellular Phone
Lg prada broken touch screen.
yes this phantom screen mystery has baffled me also, i threw my LG prada at my nuisance neighbours head & the next thing i know the screen mysteriously turned black, spooky!
Apr 07, 2008 | LG Prada KE850 Cellular Phone
Cell pjone water damage
Turn your phone off for at least a day. Dry off your phone if you haven't already. Take out the battery, dry out the inside of the phone. If you have a sim card, take that out and leave to dry. Leave the battery out of the phone for a day as well. Put it back together after a day and try to power it on. If it doesn't come on, try plugging it in without the battery in. If it works that way, you simply need a new battery.
If this doesn't work you're probably going to have to get a new phone. Your cell phone provider will be able to tell if it's water damaged, so check with them to see if they replace water damaged phones.
Nov 30, 2007 | Samsung SGH-t629 Cellular Phone
Crock pot use
You should keep the lid on as much as possible. You are correct; once you open the lid, the liquid inside can quickly lose temperature at a rate of 10-15 degrees per minute.
Additionally, taking the top off allows steam to escape, which reduces the point of cooking in a slow cooker (cooking in a relatively closed system, with the steam condensing back to water and flowing back into the broth).
It's not doing a whole lot to the flavor (aside from causing the stew to thicken with the loss of water), but it is definitely causing the cooking to take longer than it should.
Nov 02, 2007 | Rival 38601 Smart Pot 6-Quart
LG Prada KE850 Cellular Phone Logo
76 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
