Question about JVC HX-D7 Shelf System
Protect mode power turns off after protect flashes 3 times turnoff by itself after being turn on in five seconds.
  • 1 more comment
  • Anonymous Mar 05, 2008
    i turn on the system.. later on it says status protect.then it will shutdwon.thanks
  • Anonymous Mar 07, 2008
    POWER TURNS OFF AFTER PROTECT MOE FLASHES 3 TIMES TURN OFF B ITSELF AFTER BEING TURN ON IN FIVE SECONDS
  • hassib Mar 09, 2008
    hi, i am facing the same problem. my system is brand new. it sat in the storage for about 2 years. and now it wudn't turn on. can you pleasee help out and give me all the possible suggestions.
    email me the suggestoins.
    Thank you.
  • 38 Answers
Hi ,
Does your unit go into protect mode without speakers connected?.
Jango
Posted on Mar 04, 2008
  • Susan Johnson
    Susan Johnson Mar 24, 2013
    I unplugged my system and turned it on and it goes into protect mode still,
Switches off after five seconds.AVR-590
There are a few things that could be causing this to happen. The first thing you should do is check all the speaker wires connected to see if they might be touching each other somewhere. What you are describing sounds like there might be a short. Also, is the receiver well ventilated? What is happening is that it is protecting itself but shutting off.The 590 is going in to Protection Mode due to some fault it perceives. The quick flashing red power light (as opposed to a slower flashing light) would indicate either speaker wires touching another terminal, driving 4 ohm speakers to loud, or amp failure.
Jan 18, 2016 | Denon Audio Players & Recorders
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
I have a 32PFL5332D and when power turned on red light flashes 6 times then stops blinking for 3 seconds and starts again over and over. TV never powers up
Im afraid the set is probably in an over current protection mode wherebye it shuts down to protect itself as one aaea of the tv is drawing excess current, the pattern of flashes will have a code which would guide a techie to problem area, im afraid you will need an engineer visit,sorry George
Nov 03, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Jun 03, 2009 | Sharp LC-26D43U Television
Tv Turn sound on, No Picture, turns itself off within seconds
The TV is trying to go on protect mode because an internal fault had been detected. For that reson the protection circuit keeps turning off TV continuously.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
May 23, 2009 | Sony KLV-30HR3 30 in. LCD Television
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
Turns on and turns off.
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Hx-d7
You have a short in the internal power of this unit. It is going into protect and shutting itself off to keep it from damaging anymore of the internal electronics. Very likely a voltage regulator has gone bad or a power capacitor has gone bad. You will not be able to repair this yourself unless you are skilled in electronic repair. I would suggest contacting the manu and seeing if they have a authorized repair shop in your area. If not ask around and see who is a reputable repair shop in your area.
Feb 08, 2008 | JVC HX-D7 Shelf System
TV turns off by itself after being on for 60 seconds
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Hope this helps.
Jan 13, 2008 | Toshiba CN36X81 TV
Sony Wega 42" LCD HDTV
I've been trying to find th thermal fuse on a 42we655 for like 3 weeks...It's not under the lamp...Any one know where it is?
Thanks
Aug 31, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
JVC HX-D7 Shelf System Logo
448 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
