Still trying to configure the old DWL-610 as theren't many better solutions.
I get the first led blining but does not find how to configure eth1. Am i doing it right? I getting into "Hardware" I choosing to configure "Wireless". Is it right?
Thanks again!
Vinicius
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on PCMCIA card, D-Link DWL-610:
Solution #2
posted on Aug 10, 2005
jessie25 - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Get the Netgear WG511 with prism54 chipset, I've also bought first the dwl-610 and also tried both driverloader and ndiswrapper and wasn't succesfull either. Just stick to the Netgear one, it works like a charm :D
Solution #3
Cato - usenet poster
Thanks again Steven!
Now everything is working. I was having problem with the WEP. Now, I just have to reload the driver everytime I reboot the computer. It's not a big deal though, but do you have any suggestion?
Thanks again!
/Vinicius
Solution #4
Cornish - usenet poster
Having finally bought driverloader this week I have been experimenting a bit. Under Mandrake community 10.1 I have found that you can now configure the wireless settings using the Mandrake "configure your computer" tools. Once driverloader was installed and rebooted I selected "Configure your computer" -> "Network and Internet" -> "New connection" -> "eth1:" -> "next" then entered my details in the boxes.
The problem is that mandrake attempts to bring up eth1 before it has loaded the driverloader module. The second problem is, that even if I log in and type "ifconfig eth1 up" it doesn't work unless I unload and reload the driverloader module, which I think is a problem I had when I tried it in august. Has anyone else had these problems?
Steve.
Solution #5
Ranny - usenet poster
If the light is blinking then that means the driver is loaded successfully. At this point I'm afraid you will have to use the command line to finish off. You need to set the network name (the SSID) and maybe the encryption key.
You need to open a console: click on System, Terminals, Konsole. At the prompt, you need to type the following:
Solution #6
Phoebe - usenet poster
I'm not sure if there is an official solution because driverloader wasn't included in the design of mandrake. I put all the commands into a script file that made it easy to run. I suppose I could also have made that script run automatically at every boot, although I never got around to it, it was easier just to run it whenever I rebooted.
Steve.
Solution #8
I have successfully used this card with driverloader ( http://www.linuxant.com/driver loader/ ) loading the Dlink windows driver under Mandrake 10, however driverloader is not free and my 30 day trial ran out.
I have been unsuccessful getting the opensource NDISwrapper ( http://ndiswrapper.sourceforge .net/ ) to work loading either the Dlink drivers or the sugested RTL8180L drivers with modifications to the .inf file. In the case of the second driver, it loaded and recognised the card, but would not accept the SSID of the network to connect to.
Steve.
Solution #9
Grant - usenet poster
Hi!
Thanks for your help, but I cound't get it to work not even with the help of driverloader. I thinking about to buy another card. Any suggestion regarding which card to buy that is easy to get to work?
/Vinicius
