HP Ink catridge 51604A
I like to know the pin configuration of HP 51604A ink catridge ,- means contact point to nozzle number connection
  • shaju T Antony Feb 13, 2008
    Dear Metawatch,
    Thanks for your information, but I needs the pin vs nozzle configuration
    Rgds
    Shaju
  • 96 Answers
Http://www.hp.com/oeminkjet/reports/TIJ1.0.pdf
Here is a HP data sheet for the nozzle...
Unfortunately it doesn's denote the actual pin in pin out...
Posted on Feb 09, 2008
Printer will not print saying that the printer is out of ink. Test shows empty cartridges. Took the cartridges to store, they checked and said they were full, doing a test page to confirm. Is there some...
try clean the gold contacts that touches the printer and the catridge.I remember some of the pins tells the printer the leftover ink in the catridge.
the other thing is, hp ink will 'expire'. there is a fixed date stored in the chip of the catridge. if the date is expired, you cant use the ink regardless its full or empty.
Sep 22, 2011 | HP Officejet 5610 All-In-One InkJet...
After refill ink in printer cartridge it doesn't work and the light still blinking for empty ink
You catridge is not reusable.some refilled catridges may happened the same problem because of nozzles damaged.so buy one new catridge and install.it will work.
Hope this helps. If it does, pleaseaccept and rate the solution! Contact me with any more questions you may have.Thanks for using FixYa!
Jun 23, 2011 | Office Equipment & Supplies
I have an HP 2140 fax purchased one year ago. I have never replaced the catridge and have used the fax about once a month. Today I am trying to copy and it won't print. I cleaned the nozzle and still...
New cartridge wouldnt print but sounded like it was printing. You can check ink levels clean or align cartridge by pushing menu then tools. I cleaned contact points w qtip and alcohol. What seemed to work is putting alcohol on cartridge where ink is released and putting back into machine wet did this three times first time little dots of ink then a faint print and now it is printing must have been dried ink further then I could access.
Apr 12, 2011 | HEWLETT-PACKARD HP 2140 Fax
Catridge is not detectet
Printer cartridges are very sensitive especially the contact points (gold contact points) and the printer head itself. The only thing you can do is to clean the contact points and the ink head (nozzle) with a soft cloth or a cotton buds wet with a household 70% alcohol. This will soften the hardened ink You can also clean the contact point on the printer itself. Let the alcohol dries up, reinstall the cartridge then power on again. If error persist, buy new cartridges.
Good luck
TedMac
Sep 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
Does not print in color although we have a new color cartridge in there and the print preview shows that it should be in color
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Feb 11, 2010 | HP DeskJet 5650 InkJet Printer
My HP 6500 on install will recognize Cyan ink
Solution:
1. Try to determine whether the catridge is at fault. How so? Switch the Magenta with the Cyan catridge. Press OK.
2. If system indicates that the Magenta is not installed, you will know that the Cyan that you put there is at fault.
3. Touch the 9 mm. hole where you can see the sponge. Does the Cyan color transfer to your finger? If not, the catridge is empty or dried up. Replace or refill.
4. If the ink is normal, then use some toilet tissue to wipe the gold contact points clean. If this fails to solve your problem, take it to your dealer and ask for a replacement (if it fails to work in their machine).
5. If this fails, then the problem is within your HP 6500. You need a technician.
www.catherinecollege.net
Aug 08, 2009 | HP Officejet 6500 Wireless All-in-One...
Printer output is a blank page
hi,
* Please check with the ink level in the Catridge.
* Be sure that catridge nozzle is not dry or dirty.
* Check wheather ink nozzle is clogged/ damaged if so use rubbing alcohol to clean them.
* Try printing by replacing new catridge.
Thanks,
Appereciate to rate as "FixYa"
May 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
Cartridge problem
Please remove the printer catridge and clean the the extra ink in the catridge holder and in the catridge connection point with the soft cloth without damaging the cables in the catridge and the holder then test it
T.Boopathy
Jul 22, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP 3210 not printing black ink
Look at the posts on "black ink problem" later on this site (mostly Dec).
This appears to be a very common issue with this model and results from a serious design error.
You may need to force the blockage out of the black ink feeder system, a messy process.
The 9 offers on "black ink problem" give various suggestions: try the top one.
Jul 06, 2008 | HP Photosmart 3210 Printer
It thinks the ink cartridge is not installed, but it is
It's because you touched the connection side of the cartidge. Clean it with some contact cleaner(or surgical sprit)and let it dry.If possible clean the printer side of catridge contact.After both are dried well, put the catridge back.it must work.
Aug 03, 2007 | Canon PIXMA iP90 Mobile Printer
148 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
