Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
TV turns on, but it turns right back off
Hello, I've recently run into a problem with my TV where I turn it on and it turns on, the screen stays black but I am able to hear the voices of the TV program for a certain period of time, yet the screen is still black. After about a minute or less, the TV turns off by itself and restarts the process which is then repeated yet a second and third time.
After the third time, the TV turns off by itself and simply flashes three lights at me, and I'm left wondering what is wrong with it. Possibly it's the screen or something else.
If someone could suggest a possible solution to this, I would greatly appreciate it. Thank you!
  • 113 Answers
Your lamp has went bad and you need to replace it. If you look on the left side of your tv there is a sticker that has a lamp part number on it. You can order that from part store.com and you will be back up and running.
Josh
Posted on Feb 08, 2008
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Stuck at Dell splash screen.
Hello, I have pulled out hair over similar problems. You either have an internal problem inside of the TV or you are losing your source for the picture.
These sets usually have a a Menu which tells the TV to go to a certain input socket for its feeding signal. If you have a bad cable or USB plug, the TV loses its feed and displays the Base Dell Logo.
This feed can be a HDMI multiple wire, or if you have a tapeplayer, CD deck, or Computer feed, they may be toggled separately. On some of my older equipment, I need to switch the TV ports through my Remote to get the appropriate appliance to show on my TV screen.
Depending on your Warranty, you may want to call Service. Sometimes dust can cross circuit the electronics and cause the problem you have. The cable feed wire can also be shorting and causing a loss of signal. Check you cable connections.
Jan 15, 2012 | Dell W3706MC 37 in. LCD HDTV
Hello, I have a Samsung 2493hm monitor, earlier this week I turned on my computer to see nothing. My screen remained black. The power button stays on and it never cuts off, so i'm thinking it's a...
With my Samsung 2493hn, I used HDMI. Use auto detect, on front next to secondary power. Not the main power switch on back of unit. Windows 10, click notification button lower right on Taskbar. Click on Project, then choose which option.
If when you power on Monitor without white squares with HDMI, ANALOG, DIGITAL printed in each then yes sounds like back light.
Aug 02, 2017 | Samsung SyncMaster 2493HM Monitor
Hello, I'm having an issue with my Sanyo DP42848 LCD TV. When you power it on the LCD panel turns on for about 2-3 seconds then immediately turns off. You can power cycle the TV over and over and every...
It only tells us that the inverter cable needs to be reseated or replaced. It's not an expensive repair so fortunately you can consult any local certified technician and have them work on this.
Aug 30, 2011 | Sanyo DP42848 LCD TV
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
I have a magnavox model 35R502-00AA help
you tv have a problem of vertical ic or cacacitor or resistor right around vertical section. that is make tv shut down in alot of magnavox tv. good luck!
Jul 27, 2009 | Televison & Video
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Black Screen
your son could have cause your tv to malfunction call in the tech to look at it.good luck.
Apr 01, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
118 people viewed this question
Jerry Greenberg
Jerry Greenberg
