Question about Gateway 4026GZ Notebook
E Drive refuses to read DVDs.
My E Drive has decided to ignore DVD-r discs in it, preventing me from burning movies. I have absolutely no idea why it's doing this.
Any help?
  • 97 Answers
Maybe problem is that the lens of your DVD is dirty or maybe totally retiring. Because know what? CD/DVD writing wont last for a long period of time, theres also a limitation in burning. If you think that I am wrong Kindly try this:
* Clean the lens with CD/DVD cleaner
* Open the your dvd drive and clean the lens manually with cotton [also look for any damage on the board of the drive]
Hope it help!
^_^
Posted on Feb 08, 2008
My optical drive cannot read burned data dvds. However, it can burn data dvds which can be read on other computers. OPtical drive can read dvd movie discs! I cleaned the lens several time in last few...
you need to understand the mechanics behind cd/dvd reading, writing and burning. It usually means the reader is calibrated to a different layer than the dvd was burned on. Check this site for clarification. It's not my site but lots of detail on cds and dvd processes.
http://www.explainthatstuff.com/cdplayers.html
Sep 07, 2017 | Lenovo Computers & Internet
DVD recorded refuses to read dbl layer dvd it just burned
try burning the dvd's at a lower speed, most of the dbl layer drives have similar type of problems.
Jul 15, 2010 | Lite On LH-20A1H DVD RW Dual Layer Burner
Disc Error: My question is a result of a recent problem that I have been having with your product and recorded DVDs. On certain movies, I have been able to play them with absolutely no difficulty. However...
some older dvd players dont play dvdrs very well, but most wont play dvd in pal format only ntsc some movies are recorded in pal, you can change format if you are using nero on the last stage wher you click burn choose ntsc
Apr 13, 2010 | Emerson EWD2204 DVD Player/VCR
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Replacing a cd drive
The 4600 has PowerDVD to play DVDs (You should have the software CD to install it on the 3000) DVD burning software would be Roxio/Sonic, and you should have that CD too.
If you don't have the CDs, then try download.com to download Free player software and Burning software
May 25, 2009 | Dell Dimension 3000 PC Desktop
August 2005, I purchased this powermac g5. There has been a steady deterioration in the DVD player. Presently, no rented DVDs play. SONY DVD RW DW-Q28A: Firmware Revision: KAS7 Interconnect: ATAPI Burn...
OK. The movie industry strikes again! Your RENTED DVDs are the key.Hollywood made some adjustments to prevent the copying of the movies. So they put software to detect the kind of drives in which the movies are inserted. DVD/RW are capable of copying a movie, so they are disqualified as playing devices. Have it be a normal DVD player you won't be facing any troubles.
Apr 20, 2009 | Apple Power Mac G5 Desktop
Burning problem
it its a dvdrom than it wont write dvds it can only read dvds and cds
Mar 14, 2008 | Computers & Internet
Playing PC DVD roms problem
Dvd drives can read from both DVD and CD however due to technological limitations most DVD-ROM or RAM read up to slightly higher speeds for CDs than DVDs.
When burning DVDs professional companies that make prerecorded disks burn their disk at low speeds in an effort to achieve both compatibility and low errors, that is the reason their DVDs play on most DVD-ROMs. However DVDs me and you burn at home and work at high speeds are prone to errors and incompatibility with low reading speed drives.
As a result if your DVD-ROM has a low maximum reading speed then it can only read those prerecorded DVDs and only DVDs recorded at low speeds provided thre are not scratched.
I believe you managed to read those DVD movies if they were pre recorded.
Nov 29, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Dvd-rom trouble
Hi, first of all, I'd check if you have the problem with CD/DVDs burned (written on a CD/DVD writer) or you have it also with original CD/DVDs, which would be weird. Depending on your finding to the above point I'd do one thing or another, but to me does not look like a driver problem. I'd check with Toshiba support if there's a new firmware for your drive, this does improve the media the device can read and correct problems like the one you mention. To know the fimware version you're using, open device manager and go find your drive, right click on it and choose details tab. Normally the firmware revision is the number at the end of the instance. Good luck mate !
Dec 29, 2006 | Toshiba (SD-M1212-S) DVD Drive
Has trouble reading discs (intermitant) when burning
There are two common causes for these kinds of problems: software doesn't match, or media doesn't match. also, there a lack of info in here. is drive capable of reading dvd's when it is used for other purposes? 1. are you sure you got the right firmware? check for updates on brand site or on google. 2. try using several types of media from diffrent brands. some drives cannot read specific media (for instance, sony drivers sometimes having trouble with JVC media). 3. the least common, but worst option by far is a hardware problem. if drive is bad, you should try and replace it in case your warrenty didnt expire.
Mar 21, 2006 | Lite On SOHW - 1633S (show1633sbk)...
Gateway 4026GZ Notebook Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
