Question about Nikon Coolpix L11 Digital Camera
No pwer I have this unit and seldom used it. one time when i am going to use it, it does not switch on even i put a new battery. kindly help me with this problem. and if possible, give me a location of your service center in our country(Philippines). I search the net and was not able to find service center in our location kindly help.
  • susan111 Feb 20, 2008
    butch6103, i am having the same problem.  hadn't used the camera in months and when i turn it on to take a picture it turns off...annoying, wonder if it's the memory card?
    sus
  • butch6103 Mar 07, 2008
    Hi Rhythmicity,
    Thanks for the solution you gave for my Coolpix DIGIcam. I will do it and will post the result.
    thanks,
    Butch
    Problem Solver:
  • 4 Answers
What type of battery are you using? Do you have the right battery setting?
The camera's battery setting is set to "Coolpix" as the default (the original batteries it came with). If you're using regular alkalines, be sure to change this setting in the camera (Menu > set up > battery type > alkaline).
When the batteries ran out for the first time, I bought cheap dollar store batteries, and when I put them in my camera, it shut off immediately when I tried to turn it on, despite them being brand new. I found out this was because the batteries didn't have enough juice to power my camera. I replaced them with Duracell, and it worked fine after that (Panasonic, another dollar store battery works okay too).
Hope that helps.
Posted on Mar 06, 2008
99 Jeep cherokee, having a few issues. First off the battery seems to die when the jeep sits for more than a day or so. Battery and alternator have both been checked, i also put my multi-meter in series on...
I would say that both issues are related. Which isn't good news, but at least when you find your pwer drain, it will make perfect sense. If have tried many time to piece meal troubleshooting a problem like this and just wasted time, by not doing it right.
You will need an accurant clamp on amp meter, to do it though. You clamp it around the main battery cable (red side) - pull all the fuses out f your fuse box and then one at a time put them in an write down what the reading is. Once you find the drain (high amperage pull although it is off) then you can look at the fuse panel diagram and figure out what it controls.
Make sure you know the fuse panel layout and sizes before you start.
Jul 02, 2011 | 1999 Jeep Cherokee
The battery seems to drain off very fast. have to charge everyday even though seldom used
because its touch scrreen it uses aalot of battery.....if you had the phone for a while and this problem recently started happening, buy a new battery...just charge it before you go to sleppp....hope it helps
Sep 05, 2009 | LG KM900 Arena Cell Phone
Does not start up
open the cover laptop then find the memory then make a clean or replace a new memory.
Jun 25, 2009 | Acer Aspire One PC Notebook
Head unit beeps in my boat.
It is a low voltage warning beep. They will beep even with the slightest voltage dip. Very annoying. You may be able to go into the set up menu and turn it off or lower the volume of the beep.
May 01, 2017 | Rockford Fosgate Car Audio & Video
1991 mustang 2.l starter staying engaged
what happens if you pull the shift lever into gear to cut off the neutral-park safety switch? This cuts pwer from the key to the starter solenoid. If that fixes it, replace the igniton switch.
Mar 16, 2009 | 1991 Ford Mustang
Camera keeps switching off, even with new batteries
hi there.
it could be the swtich of turning it on and off so much, i have a cannon and i used it so much that the gears that brings the telephoto in and out, i used it so much it wore out the gear( and it would shut of and not come back on to get the zoom in... and had to have it sent to the dealer and they fixed it for free. and works great.. so im guessing that this might be whats wrong with yours maybe . the swtich is bad or where you put your batteries in is not making good contact...or the right kind of batteries...you can type in google the name of camera and they have a sight that people post there question and maybe they can help you.. good luck
Jan 22, 2009 | Hitachi M2 Digital Camera
Yaesu FT-727R
The Yaesu FT727R does not have any internal fuse that I know of. Straight from the Battery + terminal it goes to the on/off switch (that is coupled to the volume control). From the switch it goes to circuitry (PCB). Incidentally, it is the battery that normally has a thermal switch/fuse that cuts off when a certain temperature is reached (when charging).
Other than check the battery terminals/contacts for corrosion and do a little abrasive cleaning, am afraid you'll have to open the unit for a look and see. Should you be interested, a schematic diagram is available here.
Good luck and kind regards.
Nov 07, 2007 | Kenwood Protalk XLS TK-3130 (2 Channels)...
No pwer
Well with a clutch of cameras showing the same fault - together with other queries of a similar nature I suggest you contact Canon on an Educational level- for a bulk replacement deal. There are obviously showing a common manufacturing fault
Sep 21, 2007 | Canon PowerShot S1 IS Digital Camera
My PC not turn on
The Toshiba Pocket PC e330 is shipped with an Enabled security feature, which switches off the batteries. In order to be able to turn on the unit, the Battery Switch must be in a battery "Supply" position. Please check if the Battery Switch is in a Stop position or Supply position. The Battery Switch can be found on the lower left edge of the unit, next to the "DC-In Socket". Please see the below diagram The Battery Switch supplies or stops power to the Pocket PC. When using the Pocket PC for the first time, slide this switch to the left with the stylus pen. If you have further questions, please refer to the Instruction Manual page 2-3 (20 of 105).
Sep 08, 2005 | Toshiba e330 Pocket PC
Nikon Coolpix L11 Digital Camera Logo
209 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
