Testing of ic
What I am going to do when I will test different integrated circuits?
    Novelist:
  • 236 Answers
Be specific what type of IC. you cant just test ICs
Posted on Mar 25, 2008
2005 cts won't sift out of park, press the brake pedal and start the car, just won't shift out of park
You probably have a problem with
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components.
• The automatic transmission shift lock control solenoid
• The brake switch
• The rear integration module (RIM)
• The transmission control module (TCM) or powertrain control module (PCM)
With the ignition ON, battery positive voltage is supplied to the automatic transmission shift lock control solenoid from the ignition 3 relay. The automatic transmission shift lock control solenoid is controlled by the rear integration module. When the rear integration module (RIM) receives a class 2 serial data message from the transmission control module (TCM) or powertrain control module (PCM) indicating that the shift lever is in the PARK position the rear integration module (RIM) grounds the automatic transmission shift lock control solenoid control circuit. This causes the solenoid to energize mechanically locking the shift lever in the PARK position. When the driver presses the brake pedal the rear integration module receives the brake applied signal and turns off the ground to the automatic transmission shift lock control solenoid control circuit. This allows the shift lever to be moved out of the PARK position.
Shift Lever Does Not Move with Brake Pedal Depressed
Apply the parking brake and block the wheels.
Turn ON the ignition, with the engine OFF.
Attempt to move the shift lever out of the PARK position.
Does the shift lever move out of the PARK position?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Turn OFF the ignition.
Install a scan tool.
With a scan tool, observe the TCC brake switch parameter in the transmission data display list.
Press and release the brake pedal several times.
Does the TCC brake switch status turn ON and OFF with the brake pedal?
YES - Go to Step 4
NO - Go to Stop Lamps Inoperative in Lighting Systems
With a scan tool, observe the brake to shift control parameter in the rear integration module data list.
Does the brake to shift control status turn ON and OFF with the brake pedal?
YES - Go to Step 5
NO - Go to Step 8
5
Connect a test lamp between the automatic transmission shift lock control solenoid supply voltage circuit and the automatic transmission shift lock control solenoid control circuit at the automatic transmission shift lock control solenoid.
With a scan tool, command the brake to shift control ON and OFF several times while observing the test lamp.
Does the test lamp turn ON and OFF with each command?
YES - Go to Step 7
NO - Go to Step 6
6
Test the automatic transmission shift lock control solenoid control circuit for and open or short to battery voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 11
NO - Go to Step 8
7
Inspect for poor connection at the harness connector of the automatic transmission shift lock control solenoid. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 11
NO - Go to Step 9
8
Inspect for poor connections at the harness connector of the rear integration module (RIM). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Yes - Go to Step 11
NO - Go to Step 10
9
Replace the automatic transmission shift lock control solenoid. Refer to Automatic Transmission Shift Lock Actuator Replacement .
YES - Did you complete the replacement?
NO - Go to Step 11
10
Replace the RIM. Refer to Control Module References in Computer/Integrating Systems for replacement, setup, and programming.
NO - Go to Step 11
11
Operate the system in order to verify the repair.
YES - System OK
NO - Go to Step 2
Mar 25, 2017 | Cadillac CTS Cars & Trucks
2004 Deville: I am getting code B 1390 - Device Voltage Reference Input Circuit Malfunction - what do I do?
DTC B1390 -The DIM has an internal battery voltage sensor and a reference voltage. The DIM compares these two voltages via the two battery positive voltage circuits every 300 milliseconds. Do you know what the DIM is ?
Conditions for Setting the DTC
This code shall be set after 10 consecutive readings that the two battery positive voltages differ by 1 volt or greater.
Disconnect the dash integration module (DIM).
Measure and record the voltage from both battery positive voltage circuits of the DIM to both ground circuits of the DIM.
Compare the two recorded DIM battery positive voltage circuit voltages.
Is the voltage difference less than the specified value?
1 V
YES - Go to Step 5
NO - Go to Step 3
Test both DIM battery positive voltage circuits for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 7
NO - Go to Step 4
Test both DIM ground circuits for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 7
NO - Go to Step 5
5
Inspect for poor connections at the harness connector of the DIM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 7
NO - Go to Step 6
Important:: After replacement of the DIM perform the set up procedure for the DIM. Refer to Body Control Module (BCM) Programming/RPO Configuration .
Replace the DIM. Refer to Dash Integration Module Replacement .
YES - Go to Step 7
7
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Do you know what there saying here ? Do you know where The DIM is located . Do you know where to find a wiring diagram so you know what your testing ?
free wiring diagrams at
http://www.bbbind.com/free_tsb.html Enter vehicle info year , make , model ,engine . under system click on body & accessories, then under sub system click on body controls . Hit the search button a blue link will pop up . click on that .
Dash Integration Module (DIM)
The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules. Good luck !
Mar 08, 2017 | 2004 Cadillac Deville
P0351 code loss of power 2.3L08ford ranger,it warms slow and really need to eliminate1~voltage regulator is where?) & 2~ ground through PCM) 3~knowing limits&threashholds{sensorsIGNcircuit}?Ty 0$
P0351 loss of power ? That's not what this code is about . P0351 - Ignition Coil A Primary/Secondary Circuit ,you have a bad coil and possibly a bad coil driver inside the PCM . Do yourself a favor an take your vehicle to a qualified repair shop !
P0351 - Ignition Coil A Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
P0350 - Ignition Coil Primary/Secondary Circuit Description: Each ignition primary circuit is continuously monitored. The test fails when the powertrain control module (PCM) does not receive a valid ignition diagnostic monitor (IDM) pulse signal from the ignition module (integrated in the PCM). Possible Causes:
  • Open or short in the ignition START/RUN circuit
  • Open coil driver circuit
  • Coil driver circuit short to ground
  • Damaged coil
  • Coil driver circuit short to VPWR
Diagnostic Aids: Use the 12-volt non-powered test lamp to verify START/RUN voltage at the ignition coil harness connector.
Check the coil driver circuit for open, short to VPWR, or short to ground. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to Pinpoint Test JE .
Feb 18, 2017 | 2008 Ford Ranger
I HAVE REPLACED THE COIL PACKS AND THE COMPUTER ON MY 2006 F150,BUT I STILL GET AN ERROR CODE OF 352.WHY IS THIS ?
P0352 - Ignition Coil B Primary/Secondary Circuit Description: See the description for DTC P0350. Possible Causes: See the possible causes for DTC P0350. Diagnostic Aids: See the diagnostic aids for DTC P0350. Application Key On Engine Off Key On Engine Running Continuous Memory Coil-on-plug (COP) ignition testing - GO to Pinpoint Test JF . GO to Pinpoint Test JF . Coil pack ignition testing - GO to Pinpoint Test JE . GO to Pinpoint Test JE .
  • Open or short in the Ignition START/RUN circuit
  • Coil driver circuit shorted to ground
  • Damaged coil
  • Coil driver circuit shorted to VPWR
Check the coil driver circuit for open, short to VPWR, or short to ground. Application Key On Engine Off Key On Engine Running Continuous Memory Coil pack ignition testing GO to Pinpoint Test JC . Coil-on-plug (COP) ignition testing GO to Pinpoint Test JB . Without me testing , it's hard to say what you got going on ! Coil packs ? What engine does it have ? 5.4 L ? should have coil on plug ignition .
Jan 13, 2017 | 2006 Ford F-150 Regular
Display message faint. How can I restore brightness?
You'll need to replace the control panel. Usually very expensive.
Aug 02, 2016 | Microwave Ovens
How do I repair the four wheel drive on a 1999 Ford Ranger XLT?
It depends on what is wrong , is the 4x4 light flashing ? Are you aware of the complexity of the 4x4 system ? Has a electronic control module , has the ability to set an store DTC'S - diagnostic trouble codes !
Transfer Case The four wheel drive system is an electronic shift 4X4 system that allows the operator to choose between three different modes. The operator can switch 4X4 HIGH modes at any speed. To engage or disengage 4X4 LOW the vehicle speed must be less than 5 kph (3 mph), the brake depressed, and the transmission must be in NEUTRAL.
The shift motor sense plate, an integral part of the electronic shift motor, informs the generic electronic module (GEM) of the transfer case shift motor and contact plates A, B, C and D position.
The digital transmission range (TR) sensor is located on the LH side of the transmission, and informs the GEM when the transmission is in the NEUTRAL position.
The electronic shift motor is mounted externally at the rear of the transfer case. It drives a rotary cam which moves the mode fork and range fork within the transfer case between the 4X4 HIGH, 4X4 LOW and 2WD range positions.
When the GEM verifies the completion of the transfer case shift from 2WD to 4X4 HIGH (reading the contact plate positions), the GEM will then energize both pulse vacuum hublock (PVH) solenoids (supplying ground for 45 seconds). The PVH solenoid will allow a HIGH flow of intake manifold vacuum to the "wheel end hublocks", engaging the wheel end hubs to the front differential and transfer case to achieve four wheel drive.
Here are just a few DTC'S the system can set an store in the module !
P1804 4WD High Indicator Circuit Failure GEM GO to Pinpoint Test C . P1806 4WD High Indicator Short to Battery GEM GO to Pinpoint Test C . P1808 4WD Low Indicator Circuit Failure GEM GO to Pinpoint Test C . P1810 4WD Low Indicator Short to Power GEM GO to Pinpoint Test C . P1812 4WD Mode Select Switch Circuit Failure GEM GO to Pinpoint Test A . P1815 4WD Mode Select Switch Circuit Short to Ground GEM GO to Pinpoint Test A . P1820 Transfer Case CW Shift Relay Circuit - Failure GEM GO to Pinpoint Test A . P1822 Transfer Case CW Shift Relay Coil Short to Power GEM GO to Pinpoint Test A . P1824 4WD Electric Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 4WD Low Clutch Relay Short to Power GEM GO to Pinpoint Test A . P1828 Transfer Case CCW Shift Relay Coil Circuit Failure GEM GO to Pinpoint Test A . P1830 Transfer Case CCW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test A . P1838 Transfer Case Shift Motor Circuit Failure GEM GO to Pinpoint Test A . P1846 Transfer Case CONTACT PLATE "A" Circuit Failure GEM GO to Pinpoint Test A . Now are you sure you really want to mess with this ? You would need a factory diagnostic scan tool to check this out before you start replacing parts !
Here
May 30, 2015 | Ford Ranger Cars & Trucks
I have a Pioneer VSX-305 receiver. I blew channel A speaker outputs by allowing speaker wires to touch. Everything else works. Can anyone tell me what it takes to fix this. (I am an electrical engineer...
Without a Sams Photofact or a service manual I would go directly to the Power IC which is the largest Integrated Circuit mounted to a large heat sink. If you see any fuses they are probably for the power supply since any fused circuit on the speaker output would be ineffective because the IC would be damaged before the fuse would blow, but you need to check them anyway. Since the short was at the speaker output your problem should be at the final stage of amplification, which is the Power Amp IC. Prior to the early 70's you would have transistors mounted to a heat sink which could be individually checked and replaced. Then manufactures started to use the Power Amp IC which are more costly but eliminate having to find matched pair transistors. All you can check on the Power Amp IC is if you have an input using an oscilloscope or signal tracer and the power to the IC. If you have an input signal and power to the device with no output, I would replace the IC. Unless you have a test circuit for the IC you cannot test it completely unless you have a device like a Huntron Tracker or build a test circuit using a signal generator and a power supply to measure the gain of the IC with an oscilloscope. Short of ordering a service manual this is a good place to start.
Aug 15, 2011 | Audio Players & Recorders
I just aquired this unit from a friend who was throwing it away because he thought the speaker was blown. I tested the unit and also thought there was an issue with the speaker, however I changed out the...
hi,
If possible check the crossover circuit board. There will be two or more ICs ( integrated circuits). fast of all just replace all the ics in that board. That ics will be very cheep in price. after replacing those ics make a test. if then also the cracking sound hears then you have to check the components amplifier board.
ok
May 04, 2011 | KLH ASW12-120 Subwoofer
About the Regulator ic
your welcome, just info me if you done to test the regulator ic.
Feb 22, 2008 | Acer AL1716 17" LCD Monitor
Pioneer PL516 turntable
You have a faulty IC inside. You will need to take to a service center for repair, unless you have knowledge in testing and removing Integrated Circuits.
DJPROAUDIO
TWEAK AV LAB
Jan 18, 2008 | Philips WMM142211 Turntable
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
