Question about Memorex MVD2027 DVD Player
Buttons on front console no longer work.
All functions on remote work fine, but none of the buttons on front console (except for on/off) work anymore. unit is 6 years old.. also, the tray moves in/out much slower than it used to. plays fine using remote.
  • opie440 Jun 11, 2008
    That's it! Our 4 year old daughter has been fiddling with the remote, so that must have activated the keylock function.
    (most of those remote buttons we never even use).
    Thank you!
  • Gator_148 Jun 13, 2008
    I have lost the remote and the key lock function must have been activated by something else. How can I unlock the key lock function without the remote contol?
NO!!!! This dvd player has a KeyLock function which can be accessed by the remote which came with the player. Try to turn the keyLock off it should help.
Posted on Jun 09, 2008
    Master:
    Sergeant:
  • 440 Answers
Time to upgrade not even worth it or to find parts sound like bad controller old ok samsung upconverting one 89 bucks circuit city k betifull picture thx nick
Posted on Feb 08, 2008
I have a panasonic th42px60u my problem is that none of the controls work xcept the on and off volume is on but unable to increase or decrease the volume.
Hi Daniel,
May I know if the remote control is working fine except from the front panel's volume and channel button key?
Jdvillanueva
Nov 23, 2011 | Panasonic Televison & Video
My sony kp57wv600 will not turn off. none of the buttons on the front panel work at all what should i do ?
Hi Jimmy,
Have you try using remote commander? It seems the power button on your tv is broken. It could be on button pad, or cables connected to it. Can you try check it?
Regards
Oct 29, 2011 | Sony KP-57WV600 57" Rear Projection...
I HAVE MODEL LCT3201TD. I AM USING THE REMOTE THAT CAME WITH THE UNIT. THE REMOTE WILL TURN THE UNIT ON AND OFF,CHANGE VOLUME AND SLEEP TIMER. TO CHANGE CHANNELS I USE A SEPARATE REMOTE. I WOULD LIKE TO...
The tv remote that came with the tv unit.The tv remote might have channels buttons up/down buttons functions and numbers pads might be shorted and dead and no longer functions anymore.U have a Digital Camera turn it on take the tv rmote put in the front of the Digital Camera pushes each buttons one by one all the buttons that work u will able to see a flashing white light on the camera vewing screen,because the Digital Camera can read INFERED input signal to see a output u see on the the camera viewing screen.After u test it on the front of a Digital Camera any buttons don't have a white light flashes INFERED read out than those buttons functions are shorted and dead.Try website like Remotes.com to buy the tv original remote to replace and used.
Aug 29, 2011 | Akai LCT3201TD 32 in. LCD Television
Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Dec 14, 2008 | Zenith B27A11Z 27" TV
Viewsonic n3251w will no longer display Closed Captions
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Dec 11, 2008 | ViewSonic N3251w 32 in. LCD HDTV
Video issue
unplug connector ZF behind the speaker grill if this restores normal operation than you have bad buttons on the front of the tv.
Feb 26, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Inside buttons do not function at all.
The problem with you radio is the ribbon cable,this part connects the face to the main board.you get it from pacparts.com
parts number is 168795211
you can try to replace it by you own,just becareful with the front button because they may fall dow when you open the face.
Nov 17, 2007 | Sony CDX-M800 CD Player
Remotes Don't Work With It Anymore
have a tech check your set the ir on the front panel needs to be replaced.good luck.
Apr 13, 2007 | Sony MegaStorage CDP-CX355 300-Disc CD...
Remote won't turn set on anymore!
Hi Smittie, I had a similar problem with another type of TV set. All functions work well except power. The solution was to replace the batteries, perhaps they are running low. It will also reset the remote which might help as well. Hope this will work for you too. Cheers.
Feb 09, 2007 | Samsung TXN3271HF 32" TV
Memorex MVD2027 DVD Player Logo
120 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
