Question about KitchenAid KESC307 Electric Kitchen Range
KItchenaid supera gas stove
The stove burners work fine.
The digital panel wont luminate anything, no error codes , nothing
What heppened was it finished cleaning itself and went to unlock the door and when the lights went out.
All breakers where reset and oven unplugged for half an hour.
Still nothing.
COuld not find the fusable link under the panel. IS it in one of the burner valves????
Thanx Anthony
  • bobren Mar 25, 2008
    Almost same problem.....set the gas oven on the KitchenAid (approx. 3 years old...high end stainless steel model) to self clean. Sometime during the cleaning procedure, the panel and all lighting and displays were inoperable. The gas burners work fine, but the oven is totally out of comission. The door will not even open; remains locked from the self clean. Can anyone help me with this? There is no longer any warranty on this. Thanks.
    President:
  • KitchenAid Master
  • 2,651 Answers
Thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Posted on Feb 24, 2008
I have a Norge 3H9TZ-EV stove. The oven & broil elements stopped working suddenly & there are no fault codes. Power to the stove is good, there are no blown fuses and nothing visibly wrong with the...
I had a similar situation happen to my GE Stove. I tested the incoming wires and found power on both. I couldn't find anything wrong either.. What I did find though was that the Circuit breaker itself had "half died", meaning that only one pole of the dual circuit breaker was working. I tried resetting it over and over only to find that it was completely fried. I went to the hardware store and got a new circuit breaker. I first looked for any loose wires on the elements and the burners of the stove that could have provided a ground fault, and after finding none, I installed the new breaker and flipped it on after plugging the oven back into the wall. Voila! everything worked fine! Installing a new breaker can be scary at first. you may want to consult a professional to check the breaker for you. Or if you are comfortable doing it yourself, then go for it. At least you'll know if the breaker is good or not. Once I had the breaker off of the circuit panel I checked it for continuity with a voltmeter and found only one side working. The panel I have allows you to just "pull" the breaker straight off of the panel. Some are screwed in, some are popped in, it just depends on the manufacturer. So, based on my experience, that is what I would do. Perhaps it's the wall outlet, but I doubt it. If you want to check that, use a voltmeter to check each incoming wire for proper voltage. Some symptoms I had with my oven were the panel would be on and would "click" like it was turning on the oven, but nothing would happen. Or the Burners would work, but only heat up halfway. The Broiler wouldn't even come on at all. Let us know how it goes!
Oct 25, 2013 | Freezers
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
I Have a C970-648229 and after self cleaning mode stove top stays locked out.
Have a similar problem. The range went on locked mode w/o it being used. Disconnected the cable & it unlocked but the touch panel would not work. The clock & the stove top continuos to work though. Appreciate any help. Thank you.
Sep 09, 2012 | Kenmore Kitchen Ranges
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven wont heat up.
can you tell me the model # off the stove. sounds like you may have to replacet the TOD or the heat probe.
Jun 24, 2008 | GE JGBP28 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
KitchenAid KESC307 Electric Kitchen Range Logo
339 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
